Old 17-10-2006, 11:44 PM   #1 (permalink)
krazyfrog
Posts: n/a
Question P4 with dual core?!
My friend is getting a pc assembled for 25k. So he went to a shop to figure out a proper configuration. In the configuration given by dealer, the processor was a Pentium4 2.6 with dual core. I thought that only pentium D and Core 2 Duo had dual cores. Is it possible for a Pentium 4 to have dual cores? Similar thing was stated by few other shops. I need you opinion on this.
Old 18-10-2006, 12:30 AM   #2 (permalink)
samrulez's Avatar
Default Re: P4 with dual core?!
I think the dealer ment the Pentium D 805 coz its dual core and is clocked at 2.66GHz........but I don't think there is any dual cored p4...
But no of of getting a Pentium D its cr@p...coz the 2 cores cannnot even communicate with each other...directly...
So get a C2D....
Sam :D Rulez :lol:
samrulez is offline
Old 18-10-2006, 12:34 AM   #3 (permalink)
krazyfrog
Posts: n/a
He clearly wrote P4 with dual cores on the quotation given to my friend. Similar thing was done by the other shops. How could have they all gone wrong?
Old 18-10-2006, 10:29 AM   #4 (permalink)
sweetricha07's Avatar
hi, i think u need to check with the vendor again and be clear with him regarding the model of the processor besides it being a P4. i suggest your friend should go for something supporting EM64 tehcnology and unless he is planning for consummating virtualization and not overclocking he should take a single core processor.
sweetricha07 is offline
Old 18-10-2006, 10:50 AM   #5 (permalink)
altimate's Avatar
Hey man don't believe those VENDORS CRIPPLES
They r out there 2 make money
Search on the intels site and then fix ur configuration and then buy
##ALTIMATE##
altimate is offline
Old 18-10-2006, 11:04 AM   #6 (permalink)
Ethan_Hunt's Avatar
Pentium 4 CPU's had Hyper Threading technology in them and Pentium D CPU's are more of a Dual core revisions of Pentium 4.What your friend might have got is the D805 version on the Pentium D series which clocks at 2.66Ghz & which is the starting point of the Pentium D series.They would mostly bundle this CPU with a D101 motherboard which has a ATI Xpress 200 chipset.
V for Vendetta
Ethan_Hunt is offline
Old 18-10-2006, 12:10 PM   #7 (permalink)
18 Till I Die............
Most of them call Pentium D as Pentium 4 Dual Core, at least that's what happened to my friend. Just ask them the price of the processor, that should give you the idea whether it is Pentium D or Pentium 4.
http://www.bash.org/?258908
mehulved is offline
Old 19-10-2006, 10:23 AM   #8 (permalink)
I have come across a Big intel dealer who had ZERO knowledge of hardware. When asked if he deals in AMD X2 he replies X2 is old now is age of X5/X6. I was like WTF !!!
suhas_sm is offline
Old 19-10-2006, 10:49 AM   #9 (permalink)
Ethan_Hunt's Avatar
^the best is yet to come.Some actually believe that Pentium 5 and 6 are already out in the US.Screw any knowledge of Dual cores.
V for Vendetta
Old 19-10-2006, 02:13 PM   #10 (permalink)
Cool G5's Avatar
Smile Re: P4 with dual core?!
Pentium 4 does not have any model with dual core.I think the dealer confused Pentium D for pentium 4 with dual core.
Cool G5 is offline
Old 19-10-2006, 02:43 PM   #11 (permalink)
jz2linkinpark's Avatar
naaahhh....they are two separate categories...Pentium 4dual core and D
(\__/)
(='.'=)This is Bunny. Copy and paste bunny into your
(")_(")signature to help him gain world domination.
jz2linkinpark is offline
