My PC beeps evertime i restart it or sometimes while working on it...this is happening for the past one month...don't know which component beeps..sometimes it beeps twice after a intervel of 5-6 sec. but the second beep is like ummmm......fart(lol). is it okay or i have to call a technician..
system config
pentium 4 3.0ghz
intel 915 gev mobo
6600gt
1 GB DDR2 ram
windows xp professional
80 GB SATA(seagate) hdd
No PC beeps when its on, It should only beep once while startup...
u r HSF is not mounted properly naaa??
That's the reason, u r pc must be crossing 100 degs so the BIOS is warning u....
You will have to change RAM. If its in the warranty period then do it immediately. You have to change it sooner or later. So sooner the better.
www.techani.com
Latest post ->Take Ur Applications & Personal Settings With You
->Umpires Are Vampires
The Most Unknolegeble Parson. Plese Tech Me.
