Old 17-10-2006, 05:35 AM   #1 (permalink)
ArZuNeOs's Avatar
Default DVD Writing issue !!!!!
I have been writing DVDs for a yr till now
I have Samsung DVD writer & use Scorpio DVD as media
The Sware i use is Nero that was bundled with the writer
I write Data DVD consisting of AVi movies , songs , & raw data
I wrote one DVD consisting of 3 movies & some data ...Psst the movies were a backup of my original DVD's in AVi
The nero showed burn Successfull & 100 % verification done
But when I used to transfer the same on to my HDD again 1 out of 3 movies were copied back ......Error Data error
THen i used CD Check & it showed me error in my DVD
I dont want to retrieve the data But a solution to this ( i have a backup )
I also Converted it into ISO & tried .....the same thing happened
Is it the problem with Nero or the media or the DVD writer
Plz help
Back to the world of realms
ArZuNeOs is offline
Old 17-10-2006, 07:37 AM   #2 (permalink)
TheSaint
NucleusKore's Avatar
Default Re: DVD Writing issue !!!!!
I have an Acer DVD writer on my Acer laptop and face the same issues. My suggestion is to change your media to Moserbaer and try writing at lower speeds says 4x or 2x. It could be a problem with the writer too. My friends have a Sony dual layer DVD writer (bought on my suggestion :-S) and they're yet to have a failure!
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 17-10-2006, 08:27 AM   #3 (permalink)
samrulez's Avatar
How old is your Optic drive?? may be its in its grave!
What speed do u burn, try burning at 4X-8X...
Samsung drivers stink! Don't ever go with Samsung..!!!!!!
Sam :D Rulez :lol:
samrulez is offline
Old 17-10-2006, 08:36 AM   #4 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Its the drive.. Anyway, you can try changing media..
kalpik is offline
Old 17-10-2006, 01:24 PM   #5 (permalink)
ArZuNeOs's Avatar
samrulez my drive is less than a yr old maybe 6-7 mths
& i always burn @ 2-4x speed
Kalpik I will do that tomorrow thanks ....I was wondering y nero shows 100% burn successful & also verification success but Failure @ end use
ArZuNeOs is offline
