you can buy two bluetooth dongles and connect the computers the same way you do with a normal lan, you can search the forums, i remember vishal gupta posting on pretty much the same topic on another thread
(\__/)
(='.'=)This is Bunny. Copy and paste bunny into your
(")_(")signature to help him gain world domination.
If u still wanna go for Wireless transmission then
1. Install the usb driver program that coms bundled with the USB dongles
2. First click on the RED BALLON in the between for searching new devices.
3. It would probably detect the other computer
4. Pair thet device by right clicking on that device
5.Use the 2nd active option from the main upper menu i.e. the FILE TRANSFER
And there u go!!!!!!!!!!!!!!!!!!!!!!!!11
