Old 15-10-2006, 10:38 PM   #1 (permalink)
Default Zebronics Antibiotic Cabinet Users or anyone else who can help
Hey does anyone on here use the Zebronics Antibiotic cabinet or can help
If so how to tell the polarities of the fans and the polarities of the fan connectors of the LCD Panel.
As well as the polarities of the Speaker, HDD LED, Power SW, Reset SW and Power LED connectors to be fixed on the system panel.
The USB connectors I know as the two loose pages "manual" deals with it.
cheen is offline
Old 16-10-2006, 12:46 AM   #2 (permalink)
"The Cake is a Lie!!"
[xubz]'s Avatar
Default Re: Zebronics Antibiotic Cabinet Users or anyone else who can help
(You didn't find the Answer in Chip, did ya )
a n00bish answer: As Per my "electronic" knowledge.. Red is ALWAYS positive
Do Refer your Motherboard Manual, it'll Have More than you Imagine
[xubz] ● http://xubz.com/
[steam_id] ● http://steamcommunity.com/id/xubz
[xubz] is offline
Old 16-10-2006, 07:51 PM   #3 (permalink)
djsubbu?
anyway i posted this around the same time i posted it on chip.
cos i always desperately seeking help
anyway there is no manual, just a loose page detailing how to connect the usb port (thank **** for that) and an incomplete guide which tells how to connect the panel but does not tell anything about the polarities and about the red and black thingy, yeh i know but the problem is the wires of the panel are in random colours - green, blue, red, black, white, grey etc
anyway just gonna connect it to the wall socket once i get the win xp and then start it up, if the fans or the switches dont work ill reverse them.
cheen is offline
