Hi,
I have an
Intel Pentium D processor (805) 2.66 GHz;
Foxconn MoBo 945 Chipset with in built Graphics display;
Transend DDR 2 Jet Ram 1 GB (512 MB x 2 in dual channel);
Zebronics 500 Watts SMPS;
160 GB Seagate (7200) SATA Hard Disk;
LiteOn 16X DVD-RW;
Logitech Key Board & Mouse (cordless);
17" LG CRT Monitor;
Logitech Speakers 2.1
Bought a new Gainward GeForce 6200 Turbocabhe with 128 MB DDR2 Memory couple of days back. Connected the same in the PCI-e slot. There is no output from the card to the monitor. Tried to install the nVidia display drivers from the CD but in vain. Tested the same card in another PC of similar configuration & it works fine. What could be the possible reason? How can I make it work on my PC? Should I return the card & get a new one? Kindly suggest!
Thanks,
Ramstrong.
