Old 15-10-2006, 12:19 PM   #1 (permalink)
Default Sound problem
Hi guys....
i got pc assembled,
c2d-1.86Ghz
512X2Mb Ram DDR2
Intel 965Mobo
i also got a sound blaster audigy value sound card....
the problem is that when i playy somethin in any media player, and if i open some other window.... the sound breaks up and even the system hangs up for a moment.....
it happens always, even if im playin a song and open "my computer" , the system hangs and sound breaks up....
i tried installin sound driivers again.....but no success....
i closed all mybackground process...but still the problem continued....
even if i use m,y onboard sound controller...the same problem is there.....
i checked the DMA access...everything is enabled....but still nothing is solving myproblem.....
even while playin games....there is continous hang up's, so its sorta makin mylife difficult
coz i have 7600 GT card and i cant wait to playgames with it....
but "sound" is troublin me ....
plz guys help,
will re-installation of the operating system help ?!?!?
saisrikar is offline
Old 15-10-2006, 02:25 PM   #2 (permalink)
Stalker's Avatar
Default Re: Sound problem
Have u re-installed WinXP lately?? If yes, re-install it again
this had happened 2 me once when i had reinstalled XP......so again re-installed XP and the problem was gone....
| C2Q Q6600 G0 | Intel DG33FB | 4 GB Corsair 6400C5G DDR2-800Mhz | XFX 8800GTX | CM Extremepower 600W | 250GB Seagate HDD | Lite-ON 1635S DVD RW | Logitech MX-518 | Zalman RS6F | APC RS 800 |
Stalker is offline
Old 15-10-2006, 02:50 PM   #3 (permalink)
thnkx brutha....
thnkx for the reply,
i was thinkin the same thin....
d guy frm whom i got the pc, installed winxp prof. onto it.....
well i will try re-installin....
and hey can ya'll tell me, wat is diff bet NTFS and FAT32...??
which one is better to use wit Windows XP ?!
Old 15-10-2006, 05:17 PM   #4 (permalink)
Stalker's Avatar
i would recommend NTFS with WinXP........
Also check
http://www.theeldergeek.com/ntfs_or_...ile_system.htm
Stalker is offline
Old 16-10-2006, 11:09 AM   #5 (permalink)
AFK
thewisecrab's Avatar
Its better to use NTFS over FAT32 any time.for more info check the NTFS vs FAT32 tread in software troubleshooting
Follow me on http://twitter.com/thewisecrab
"This Jen, is the internet"
thewisecrab is offline
