Old 15-10-2006, 12:01 PM   #1 (permalink)
Default keyboard problem-simple one
my keyboard acts wierdly since i got a internet connection.....
so is it a hardware problem or a software problem..whn i press 'Esc' it does both 'its own function' and also 'my computer comes up' and when i press key 'a' then the it acts as the windows key and the start menu in taskbar is opened.....pls do give answers
maxkool is offline
Old 15-10-2006, 12:36 PM   #2 (permalink)
jz2linkinpark's Avatar
Default Re: keyboard problem-simple one
are you using a very good keyboard?(i.e: one which has drivers or which is wireless), because if you are, it is probably a driver problem or because of low battery
(\__/)
(='.'=)This is Bunny. Copy and paste bunny into your
(")_(")signature to help him gain world domination.
jz2linkinpark is offline
Old 15-10-2006, 09:28 PM   #3 (permalink)
nope i have a ikey key board and a wired one and i just wanted some advice before tryin some of my amateur skills on it
maxkool is offline
Old 15-10-2006, 10:45 PM   #4 (permalink)
Super Hero - Super Powers
n2casey's Avatar
Just check the pin. Have u connected it correctly? (Most common reason for such prob is KB is not connected properly.)
Minds are like Parachutes :arrow: They work best when open
n2casey is offline
Old 15-10-2006, 10:56 PM   #5 (permalink)
Anindya's Avatar
Wink Re: keyboard problem-simple one
Whatever keyboard u r using it doesnt matter. Please reinstall or update its driver if u have not done so.
www.techani.com
Latest post ->Take Ur Applications & Personal Settings With You
->Umpires Are Vampires
The Most Unknolegeble Parson. Plese Tech Me.
Anindya is offline
