15-10-2006, 09:29 AM
~[::BOoYaKa::]~
Help! Cant Run MoH:AA
When i run Medal of honour:allied assault, it gives me following error.......
--- Common Initialization ---
Medal of Honor Allied Assault 1.00 win-x86 Dec 6 2001
----- FS_Startup -----
Current search path:
D:\Medal Of Honour\main\Pak5.pk3 (259 files)
D:\Medal Of Honour\main\Pak4.pk3 (593 files)
D:\Medal Of Honour\main\Pak3.pk3 (669 files)
D:\Medal Of Honour\main\Pak2.pk3 (4722 files)
D:\Medal Of Honour\main\Pak1.pk3 (772 files)
D:\Medal Of Honour\main\Pak0.pk3 (11175 files)
D:\Medal Of Honour/main
18190 files in pk3 files
execing default.cfg
execing menu.cfg
execing newconfig.cfg
Config: unnamedsoldier.cfg
couldn't exec configs/unnamedsoldier.cfg
couldn't exec localized.cfg
execing autoexec.cfg
Unknown command "fov"
couldn't exec custom.cfg
...detecting CPU, found Intel Pentium III
------- Input Initialization -------
Initializing DirectInput...
Couldn't set DI coop level
Falling back to Win32 mouse support...
------- Input Initialization Complete ------- 28
You are now setup for easy mode.
----- Client Initialization -----
Called FadeSound with: 0.000000
----- Initializing Renderer ----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\WINDOWS\system32\opengl32.dll' ): succeeded
...setting mode 4: 800 600 FS
...using colorsbits of 32
...calling CDS: ok
...registered window class
...created window@0,0 (800x600)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 24, 8 )
...35 PFDs found
...GLW_ChoosePFD failed
...GLW_ChoosePFD( 32, 24, 0 )
...35 PFDs found
...failed to find an appropriate PIXELFORMAT
...restoring display settings
...WARNING: could not set the given mode (4)
...using colorsbits of 16
...calling CDS: ok
...GLW_ChoosePFD( 16, 16, 0 )
...35 PFDs found
...WARNING: could not set the given mode (3)
...shutting down QGL
...unloading OpenGL DLL
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available
GLW_StartOpenGL() - could not load OpenGL subsystem
Can anyone help??
[::Eddie n Benoit Live Forever::]
15-10-2006, 09:59 AM
Google Bot
Re: Help!
do u hv a graphic card??
15-10-2006, 10:30 AM
Re: Help!
U dont' seem to have a graphics card ehhh ...
15-10-2006, 11:00 AM
Re: Help!
dear plzzz install graphics card driver!!!
Friends, Plzzz Visit my website
http://www.gursimran.c-o.in/
add ur link to my Database and signup it is Free!
Plzzz do not forget click on Advertisements, coz i need $$
Cheers,
Gursimran.
15-10-2006, 12:08 PM
Re: Help!
yup...either you haven't got a graphics card or you haven't installed the drivres properly
(\__/)
(='.'=)This is Bunny. Copy and paste bunny into your
(")_(")signature to help him gain world domination.
15-10-2006, 12:36 PM
A Year Closer To Heaven
Re: Help!
Guys, its MoH:AA for heavens sake. This game can run like a beauty even on an ancient on-board graphics card. SO forget about having to get a gfx card for it. I assume that the drivers are corrupted. Try to reinstall your on-board cards drivers along with the sound drivers as well and then reinstall the game.
And next time please name the thread in a more detailed manner.
15-10-2006, 02:11 PM
~[::BOoYaKa::]~
Re: Help! Cant Run MoH:AA
MY config:::::
P4 1.6 GHz, 256MB RAM, SiS 300 graphics card 32MB, i think this is enough!(i dont have onboard graphics)
The problem is with openGL i think...... How to enable openGL, on this card???
15-10-2006, 02:19 PM
does SiS support Opengl??....well i think u shud install Glsetup
| C2Q Q6600 G0 | Intel DG33FB | 4 GB Corsair 6400C5G DDR2-800Mhz | XFX 8800GTX | CM Extremepower 600W | 250GB Seagate HDD | Lite-ON 1635S DVD RW | Logitech MX-518 | Zalman RS6F | APC RS 800 |
15-10-2006, 02:51 PM
It is mostly your GPU.
Anyway, try the demo, does it run?
Is the game pirated?
15-10-2006, 04:09 PM
Yes, SiS supports OpenGL. Infact I completed the game on a similar setup almost 4 years back.
15-10-2006, 04:45 PM
Try the last driver update for the SIS card from here.Perhaps it might add the native open_gl support drivers but then again don't expect a lot from the performance on the gaming front.
V for Vendetta
15-10-2006, 05:05 PM
yeah! medal of ....... allied should work....it had worked on my unichromell crap...
Sam :D Rulez :lol:
15-10-2006, 05:13 PM
15-10-2006, 07:40 PM
srtest.com, they should be able to tell you whether a game is supported by your system or not.
16-10-2006, 08:38 AM
~[::BOoYaKa::]~
From where to install Glsetup??
I havnt tried the demo. Yes the game is cracked, bought from eBay.
16-10-2006, 10:33 AM
Originally Posted by REY619
Yes the game is cracked.
This is a reason enough for this thread to be locked. Thank you.
