Old 14-10-2006, 12:34 PM   #1 (permalink)
caleb's Avatar
Default MIDI to USB connection...is my PC compatible?
I want to conenct my CASIO CTK700 Electronic (Piano) Keyboard to my PC with a MIDI to USB cable....according to the Casio manual the keyboard can be conencted to the PC...but I'm not sure if my PC is compatible.
The piano has MIDI IN & OUT ports and my local music shop is selling a Yamaha MIDI to USB cable for Rs.2500 but before I make that investment I'd like to know if my following PC is compatible.
My Config:
Processor: Intel D805
Motherboard: D101Ggc (with ATI Radeon200 Chipset) with 6 USB ports
No dedicated sound card (it is inbuilt)
Graphics Card: XFX7600GT
RAM: 1GB DDR (512X2)
OS: Win XP Media Center 2005
Please let me know ASAP as I'd like to purchase as early as possible as I've waited for this cable for a very long time (as it wasn't available till now and the local music store has only one of them).
Thanks in advance for your help.
caleb is offline
Old 23-10-2006, 03:07 PM   #2 (permalink)
Default Re: MIDI to USB connection...is my PC compatible?
Your PC is compatible, all you need is to make sure that there is software to support it.
May be you can take ur keyboard to the shop and have trial there.
Ricky is offline
