Old 13-10-2006, 12:52 PM   #1 (permalink)
Question Video Memory Problem
My Mother board : Intel Desktop Board D845GVSR.
Processor : Pentium 4 2.66 Ghz,512 MB RAM.
When i go in to the bios there i find a setting that i can change my video card memory..There i can keep maximum to 256 MB,but whatever i keep there its not getting any effect,after booting and loggin in when i check the video card memory it shows only 64 MB.
What shall i do..anyone pls tell me..
sandinesh is offline
Old 13-10-2006, 05:12 PM   #2 (permalink)
jz2linkinpark's Avatar
Default Re: Video Memory Problem
maybe your not saving and exiting, or maybe you may need to enable advanced preferences of bios by pressing one of the f keys
(\__/)
(='.'=)This is Bunny. Copy and paste bunny into your
(")_(")signature to help him gain world domination.
jz2linkinpark is offline
Old 13-10-2006, 05:19 PM   #3 (permalink)
samrulez's Avatar
Also r u sure it was not ''AGP Aperture Size'' ?? but ''Onboard VGA Frame Buffer Size''??
Sam :D Rulez :lol:
samrulez is offline
Old 13-10-2006, 05:26 PM   #4 (permalink)
in 845 chipset u cant share more than 32 mb of memory .....the video memory sharing can go upto 64 mb dynamicaaly
signature??? :???: Let Me Think About It!!!:-D
paul_007 is offline
Old 13-10-2006, 06:23 PM   #5 (permalink)
Google Bot
Pathik's Avatar
sam is rite.. Its agp aperture size so changing it to more dan 64mb wont make ne diff on ur v ram
Pathik is offline
Old 13-10-2006, 06:39 PM   #6 (permalink)
Ethan_Hunt's Avatar
The onboard memory of 845 is capped at 64MB of sharing.Regardless of any amount that you fiddle around with the BIOS settings it won't budge.Forget increasing the onboard memory and switch to a Graphic card in case you need a performance boost.
V for Vendetta
Ethan_Hunt is offline
Old 13-10-2006, 07:16 PM   #7 (permalink)
Google Bot
Pathik's Avatar
@abv.. If u change the aperture size to 32mb then it ll surely budge...
Pathik is offline
Old 13-10-2006, 08:01 PM   #8 (permalink)
nishant_nms's Avatar
U can not increase it
nishant_nms is offline
