its perfectly normal...btw which HDD do u have...for seagates this temp is generally at low disk usage and shoots upto 50 degrees on full load...My western digital goes only upto 45 degrees on full load...
there is no need for a cooler at all..
Integrate Yourself With The Latest Happenings.....
www.ankur-gupta.com/blog
My laptop's HDD @7200 rpm runs normally at 50-52 and sometimes at heavy usage reaches abt 60.
When i give it a little ventilation then it remains at 48-50
Is it normal ?????
I use HDD temperature
