Old 12-10-2006, 04:17 PM   #1 (permalink)
Alter Bridge=GOD
nish_higher's Avatar
Default Need A Sound Card
suggest the best sound card thats easily available.price no matter.
Apple Macbook Pro 17 :cool:
nish_higher is offline
Old 12-10-2006, 04:38 PM   #2 (permalink)
Come get Some
DukeNukem's Avatar
Default Re: Need A Sound Card
buy a pocket FM radio (lol)
go for Creative X-Fi Elite Pro or
follow http://www.creative.com/products/welcome.asp?category=1
DukeNukem is offline
Old 12-10-2006, 07:58 PM   #3 (permalink)
blademast3r's Avatar
I believe this one costs nothin less than 50k...why dyu need such an expensive one??
blademast3r is offline
Old 13-10-2006, 02:22 AM   #4 (permalink)
 Macboy
goobimama's Avatar
Depends on what speaker system you are using.... can't use liquid nitrogen to power a Maruti 800
I'm like a bird... :)
goobimama is offline
Old 13-10-2006, 03:01 AM   #5 (permalink)
plz mention ur budget, if ur budget is low ~1.5k go for creative sound blaster 5.1
Intel Pentium triple3core 5.5Ghz intel original D502 GCCL Mobo 50 Gb DDR-4RajaPathar 2048Mhz 40 TBHDD EX12500XFX2GbDisplay SonyBlueRay+/-RW80.5GB
return_of_vengeance is offline
