Old 11-10-2006, 10:13 PM   #1 (permalink)
bang bang!
Chirag's Avatar
Default DVD Writer (Urgent!!!!)
First of all curse me as much as u want and don't ask me to search . I did and found results but damn confused.
Now I m gonna buy Dvd writer tomo. Jst tell me one thing - R ASUS dvd writers good? Anyone experienced anything bad with that company writers? Which model is best in ASUS. Well ok there r more things and not one.
Its damn urgent.
Chirag is online now
Old 11-10-2006, 10:16 PM   #2 (permalink)
gooby pls
Third Eye's Avatar
Default Re: DVD Writer (Urgent!!!!)
Lite-on is the best,don't know the model no.
Third Eye is online now
Old 11-10-2006, 10:17 PM   #3 (permalink)
bang bang!
Chirag's Avatar
No no. Leave liteon, benQ and all. Coz of some probs I have to go with ASUS. Tell me only abt ASUS.
Old 11-10-2006, 10:43 PM   #4 (permalink)
Stalker's Avatar
goto techtree.com and search......they hv reviews of asus writers
| C2Q Q6600 G0 | Intel DG33FB | 4 GB Corsair 6400C5G DDR2-800Mhz | XFX 8800GTX | CM Extremepower 600W | 250GB Seagate HDD | Lite-ON 1635S DVD RW | Logitech MX-518 | Zalman RS6F | APC RS 800 |
Stalker is offline
Old 11-10-2006, 10:55 PM   #5 (permalink)
bang bang!
Chirag's Avatar
It would be better is some member at this forum give his review.
Old 11-10-2006, 10:57 PM   #6 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
U can go with ASUS without any confusion.
ASUS products are Quality products.
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 11-10-2006, 11:10 PM   #7 (permalink)
bang bang!
Chirag's Avatar
Thnx but which model is good?
Old 11-10-2006, 11:22 PM   #8 (permalink)
Microsoft MVP
I don't know about any particular brand, but u can go for this model:
http://forum.cdfreaks.com/showthread.php?t=184759
Old 12-10-2006, 12:00 AM   #9 (permalink)
The Devil's Advocate
iMav's Avatar
my vote to sony ....they hav dru something model series
http://beingmanan.com
iMav is offline
Old 12-10-2006, 12:23 AM   #10 (permalink)
JGuru's Avatar
Sony DVD Writer Model No. DRU 820A is a very good one. Some say Pioneer
DVD writer is the best. Though it would be a bit more expensive than others. Also
You must check for Pioneer service center in your place before buying it!!!
* Imagination is more important than knowledge.
-Albert Einstein
JGuru is offline
Old 12-10-2006, 01:18 AM   #11 (permalink)
hey asus dvd writer are very bad , mine was damaged in juz 3 months & i have sent it back to s4ervice station.
Intel Pentium triple3core 5.5Ghz intel original D502 GCCL Mobo 50 Gb DDR-4RajaPathar 2048Mhz 40 TBHDD EX12500XFX2GbDisplay SonyBlueRay+/-RW80.5GB
return_of_vengeance is offline
Old 12-10-2006, 01:35 AM   #12 (permalink)
shashank4u's Avatar
go for liteon or benq only..
Be like a postage stamp-stick to one thing until you get there.
shashank4u is offline
Old 12-10-2006, 02:26 AM   #13 (permalink)
You'r Born Free
int86's Avatar
Asus will not support cheap media.
If u r going to use quality medis(moser bear, sony etc) then only go for Asus.
And plese not go for LiteOn 1633, as its a ols model.
# Money, Beauty and Configration has no ends.
# Life is like game sometimes. Play it or loose it. But keep the spirit of game.
http://en.wikipedia.org/wiki/Right_to_Information_Act
int86 is offline
Old 12-10-2006, 07:19 PM   #14 (permalink)
bang bang!
Chirag's Avatar
Well something happened. Yes u can say magic. My bro is allowing me to buy benQ now. He is not strict or something like that. He was saying no coz his 2-3 frnds who got benQ 1650 all had bad experiences. Everyone. Not me trying for BenQ 1650. Good choice na? If anyone had some bad experience with it plz tell.
Old 13-10-2006, 07:42 PM   #15 (permalink)
Tux Fan
shaunak's Avatar
Get either liteOn or samsung.
Samsung have recently launched the fastest DVD writer. you can consider that.
Cheers
Shaunak
Feel free to PM/email me.
shaunak is offline
Old 13-10-2006, 08:04 PM   #16 (permalink)
ASH_DSG
Posts: n/a
Its damn urgent.
I think Samsung is better coz I use only samsung optical drives and I find no one better then it. Try it if u want asus then go and buy it ok.
Old 14-10-2006, 01:38 AM   #17 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
BENQ 1650, 1655,,any both r good..else LITEON
wizrulz is offline
Old 14-10-2006, 08:00 AM   #18 (permalink)
You'r Born Free
int86's Avatar
BenQ 1650 is not currently available. 1655 is a lightscribe one.
int86 is offline
