Old 10-10-2006, 06:52 PM   #1 (permalink)
Can you hear it..??
windchimes's Avatar
Default USB drive not working on my machine
Hi,
I've purchased a kingston 1gb usb drive..it worked fine...but these days my machine is not showing the contents of the drive even though it detect it. Sometimes it'll show an error pointing it as "USB device not recognized". And interestingly, at times I get a glimpse of my files for 5secs n then it'll go blank...What would be the problem..??? probably with the port...huh ? plzzz help me...thanking you.
regards
Windchimes
windchimes is online now
Old 10-10-2006, 07:00 PM   #2 (permalink)
jz2linkinpark's Avatar
Default Re: USB drive not working on my machine
if its the port, then put it into a different one, if not, try formatting the drive.
(\__/)
(='.'=)This is Bunny. Copy and paste bunny into your
(")_(")signature to help him gain world domination.
jz2linkinpark is offline
Old 10-10-2006, 07:15 PM   #3 (permalink)
Booting Nicotine!!
spironox's Avatar
check the boot setup
if u have set the usb config some where to disabled!!
also if ur having xp rightclick on my computer >properties> hardware > see if the usb is wrking fine there or not !!
http://spironox.blogspot.com
Rig : Asus P4 p 800SE ( happy )
Netbook : Google chrome Cr-48 Mario !!! now that's what i call lucky & also an iBookG4 (2004)
spironox is offline
Old 10-10-2006, 08:45 PM   #4 (permalink)
-The BlacKCoaT Operative-
Rollercoaster's Avatar
the port is loose.. may be interwiring is loose if it is a fron panal port.
try on another port/system
Rollercoaster is offline
Old 10-10-2006, 09:30 PM   #5 (permalink)
Tech Geek's Avatar
Try in another computer.Even then it is not working then may the USB is ....
if it is working there is problem with ur pc. Try formatting ur pc.
Tech Geek is offline
