Old 09-10-2006, 09:10 PM   #1 (permalink)
ASH_DSG
Posts: n/a
Red face Amd Sempron 64 Bit 3200+ Or Athlon 64 3200+ 939 Socket
Hi Friends,
I need ur help again I thought why to buy an agp card I should upgrade my pc from intel to amd but my budget is limited so I had only two choice sempron 64 3000+, 3200+ or athlon 64 3000+, 3200+ which should I buy my range is around ** Rs.5500 ** for processor+motherboard so I also want a mobo which has inbuild graphics and of nvidia or ati chipsets . So can u tell me which motherboards I should buy and are avilable in Delhi and what could be the price of processors and motherboards please tell me friends I'll be waiting for ur reply will my single side ddr400 ram work o that mobo or I've to buy a new on please reply soon. I'll be waiting for ur answer ok bye.
Old 09-10-2006, 10:51 PM   #2 (permalink)
Default Re: Amd Sempron 64 Bit 3200+ Or Athlon 64 3200+ 939 Socket
i would suggest get a second hand amd 3200+(939).......(processor doesnt get bad easily...and last really long...so take into consideration).......
and for mobo there is 1 with inbuild graphics.......frm msi get that...ifu have agp card than make sureu get agp based mobo.....
ram wont b a problem whether its ss or ds........but 256mb looks quite less sell that and get 512mb one atlest
magnet is offline
Old 10-10-2006, 01:15 PM   #3 (permalink)
samrulez's Avatar
5500 is a little low...
But if u get a 7.5k.......then get a 3000+ 3000 bucks....and a A8N-VM...for 4k..
And if u go for a used.....get a 3500+ for 3k...A8N-VM for 3k...
Sam :D Rulez :lol:
samrulez is offline
Old 10-10-2006, 07:52 PM   #4 (permalink)
ASH_DSG
Posts: n/a
Thanks Friends,
But I think I should buy a New Sempron 64 bit 3200+ and the mobo will be approx to Rs. 5000-6000 is it ok will sempron 64 bit run more efficiently and better then my current cel. 2.53 and will amd support all softwares like photoshop, linux, video eding, microsoft's all software please tell me what should I do.
Old 10-10-2006, 07:55 PM   #5 (permalink)
jz2linkinpark's Avatar
^^: it will perform notably better than your current celeron processor
(\__/)
(='.'=)This is Bunny. Copy and paste bunny into your
(")_(")signature to help him gain world domination.
jz2linkinpark is offline
