| Forum |
#3 (permalink) |
a_g = JPKN
in my case, i experienced these CRC erros on my Original GTA San Andreas Game DVD, & the culprit was my DVD Drive, i just cleaned it (with cleaning CD) & the error was gone.
if you're getting CRC errors on heavely scratched CD/DVD, then i doubt there's any way to save your data. But there are loads of CD/DVD Data Recovery application, you can try them like "CD DVD Data Recovery" http://www.008soft.com/
★----------�----------★ _ ★----------�----------★ |
#4 (permalink) | |
Bayerische Motoren Werke
File not found. Should I fake it? (Y/N) |
#5 (permalink) |
it happens somtimes due to 1)scratch on the disk OR 2)drive read prob OR 3)if the disk is copied from a bad source......
u can overcome case 1 and 2 by cleaning the drive lens and disk...
eXPerience is what a MAN learn's fROM..... |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
