Old 04-10-2006, 11:46 PM   #1 (permalink)
techdoc's Avatar
Default suggest a solution for this pc upgrade
hi guys i currently have an amd athlon 2600 processor,asus a7v8xmx motherboard and ddr 384 mb of ram.i was having trouble with this mobo initially onwards.i have already got it repaired three times since it was bought.(its now 2 years old)there is one more year of warranty left.recently my mobo has started to behave strangely again.it fails to detect one ram module(one particular slot)and sometimes wont boot at all..
so i am thinking of replacing the mobo.what should i do??go for a new mobo or new mobo with processor and ram??suggest your opinions and also do suggest the model no too.cheers.........
HEARD OF A NEW CARD GAME????
"It's called LINUX Poker.everyone gets to see everyone else's cards,everything's wild,you can play off your opponent's hands,and everyone wins except Bill Gates,whose face appears on the Jokers"
techdoc is offline
Old 05-10-2006, 12:11 AM   #2 (permalink)
deathvirus_me's Avatar
Default Re: suggest a solution for this pc upgrade
Upgrade ... The cheapest would be a 3000+ with a A8N VM CSM with atleast 512 MB ram
deathvirus_me is offline
Old 05-10-2006, 05:48 PM   #3 (permalink)
Tanmay's Avatar
Hmm you can go in for a new Mobo and New Procc.You can get the AM2 based one but then you'll have to change your RAM to DDR2 or else get the Socket 939 based AMD which soon will be phased out.The Choice is yours !!
Tanmay is offline
Old 05-10-2006, 09:37 PM   #4 (permalink)
techdoc's Avatar
what about a motherboard replacement only??in that case what could be the options/models??
techdoc is offline
Old 05-10-2006, 09:54 PM   #5 (permalink)
samrulez's Avatar
yeah! for budget get a 3000+ for 3.8k OC it to a 3800+ or a 3500+ ....get 1GB ram and a ASUS A8N-VM CSM....
Sam :D Rulez :lol:
samrulez is offline
Old 06-10-2006, 10:49 PM   #6 (permalink)
techdoc's Avatar
is asus A8N-VM CSM the best mobo (cost and features wise) for an amd 939 pin 3000 processor??arent there any msi/gigabyte ones??i am lil wary of asus mobos due to my bad experience this time.
__________
also one more thing its very helpful if someone can verify linux support for this asus mobo.would i be able to run xgl using this onboard graphics??thanks all of you guys for your responses.its very much appreciated..
__________
how about replacing the mobo with a asus a7n8x-e deluxe edition??is it available now??if yes can you guys suggest a graphic card for under 3.5k.i am not a gamer just need to run xgl..do share your thoughts on this..
techdoc is offline
