Old 04-10-2006, 09:47 PM   #1 (permalink)
shyamno's Avatar
Default Do I really need Sound Card.
I am using compaq PC and do not have any 5.1 channel sound card or it would
be better to say I do not have any extra soundcard installed in my PC.
I am having integrated AC'97 realtek Audio( I think its not 5.1 compatible because there is only 1 line out jack in my PC)
But the problem is that I am buying Altec Lansing 251 5.1 Channel speaker
system,So for these does I really need Sound card or I am hear Music
without it.
If NOT which sound card would be a better choice???
shyamno is offline
Old 04-10-2006, 10:19 PM   #2 (permalink)
Tanmay's Avatar
Default Re: Do I really need Sound Card.
Get some cheap Creative 5.1 Card for under 2500Rs. Don't buy the high end ones like the Creative SoundBlaster X-Fi cause the Speaker are low end.
Tanmay is offline
Old 05-10-2006, 07:46 AM   #3 (permalink)
shyamno's Avatar
Would Creative Liver 5.1 24-bit a better choice
or Sound Blaster Audigy value?
How much both would cost??
shyamno is offline
Old 05-10-2006, 07:36 PM   #4 (permalink)
I have hcl beanstalk, motherboard asus p4 800 vm, onboard graphics and sound( sound max), 865g chipset, 256 ddr400 Mhz ram, can anybody suggest I have to buy soundcard and graphic card if so suggest what. I am planning to upgrade my pc......
sanju is offline
Old 06-10-2006, 03:41 AM   #5 (permalink)
i have creative soundblaster 5.1 & bot it for 1.3k rocks
Intel Pentium triple3core 5.5Ghz intel original D502 GCCL Mobo 50 Gb DDR-4RajaPathar 2048Mhz 40 TBHDD EX12500XFX2GbDisplay SonyBlueRay+/-RW80.5GB
Last edited by return_of_vengeance; 06-10-2006 at 03:46 AM. Reason: Automerged Doublepost
return_of_vengeance is offline
Old 06-10-2006, 03:59 PM   #6 (permalink)
Tux Fan
shaunak's Avatar
Yes you do need a 5.1 card evnt to connect all the speakers. A creative card under 3K should suffice for daily use.
Cheers
Shaunak
Feel free to PM/email me.
shaunak is offline
Old 06-10-2006, 05:16 PM   #7 (permalink)
i am also using creative sounblaster 5.1 card and it is doing a fine job.....go 4 it...best and cheap
signature??? :???: Let Me Think About It!!!:-D
paul_007 is offline
