Old 03-10-2006, 10:16 PM   #1 (permalink)
D PrankMaster
prankie's Avatar
Default System restarts!!!
I have a sempron 2500+ OC'ed to 1.53Ghz, with 512 MB RAM and is running on Windows XP pro (Genuine)..
Recently my system started giving problem.. it restarts every now and then..
i scanned my pc and found "Trojan house Backdoor.Agent.atu" on c:\windows\svchost.exe
i removed it.. but still the prob prevails..
plus aftr removing this virus, when ever i disconnect and reconnect my bb connection, system fails to connect to the internet.. so i had to restart the system to reconnect!!
I am using zonealarm pro firewall and AVG Pro antivirus.
My Rig: AMD Phenom II 1090T | Gigabyte GA880GM-USB3| Sapphire HD6850 | 2x4GB Corsair Vengeance DDR3 1600Mhz | 2x500GB Seagate HDD | Silverstone Strider 500W | Alteclansing Octane 7 | Microsoft Natural Ergonomic 4000 | Logitech MX518 | Rantopad H1 | APC 0.6KVA
My Gadgets: Nikon D3100 | PSP1000 | XBOX360 20GB | Sansa Clip+ | Soundmagic PL50 | Meelectronics M9BK
prankie is online now
Old 03-10-2006, 11:17 PM   #2 (permalink)
Smile Re: System restarts!!!
hey i had a somewat similar kind of problem , & later i came to know that Zone ALarm was the culprit, so try disabling it...
Intel Pentium triple3core 5.5Ghz intel original D502 GCCL Mobo 50 Gb DDR-4RajaPathar 2048Mhz 40 TBHDD EX12500XFX2GbDisplay SonyBlueRay+/-RW80.5GB
return_of_vengeance is offline
Old 04-10-2006, 09:45 PM   #3 (permalink)
Distinguished Member
anandk's Avatar
Default Re: System restarts!!!
the legit ms svchost is situated in C:\WINDOWS\SYSTEM32\SVCHOST.EXE
a malware can b named anything. posbly ur svchost was a trojan. i DONT THINK za could b d culprit, btw; nevertheless do disable za and c if it helps. some more info from u or ur hijackthis logfile could b of help...so do post it here.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
