****ROCKTHEGOD's Easy GUIDE to BURNING 800 MB CDs****
For Overburning CDs or burning 90 min/800MB CDs... u need 2 do the following..
1) Make sure u have Nero 6.0 or better.
2) Make sure ur drive detects 800 MB CDs (as 703 MB Blank of course). Otherwise get ur manufacturer's latest firmware upgrade.
3) ENable Overburning from from File>Preferences>Expert Features
Set "Enable Disc-at-once CD Overburning" to 99 min.
4) Make a new compilation less than or equal to 800 MB and Set the "Write Method" to "Disc-at-once" mode in the Burn dialog window.
5) Burn The poor CD happily !!!
Important:
** Always make sure whether ur drive supports 800 MB CDs and Overburning.
** During Firmware Upgrade.. be sure to hv a UPS. If nething nukes up at that time, then ur Drive will go for a repair. Always check the firmware upgrade version number and ur drive Firmware ID be4 upgrade.
** Always go for a test run with a CD RW be4 u proceed actually.
** Ignore any warnings of overburning tht may pop up.
