Old 01-10-2006, 07:07 PM   #1 (permalink)
Default HDD Problem
I have a Samsung HDD (SP0822N). Its capacity is 80GB but the computer is showing its capacity as 31.2GB. What happened to the rest of the space? Please help.
tharkiman is offline
Old 01-10-2006, 08:07 PM   #2 (permalink)
samrulez's Avatar
Default Re: HDD Problem
go to disk management tool and see if all the space is formated.
Sam :D Rulez :lol:
samrulez is offline
Old 01-10-2006, 08:13 PM   #3 (permalink)
gooby pls
Third Eye's Avatar
Have you created only 1 Disk (means C Drive) ?
Third Eye is online now
Old 01-10-2006, 08:27 PM   #4 (permalink)
Stalker's Avatar
how many partitions?? have u formatted the entire drive??
goto disk management and check..
| C2Q Q6600 G0 | Intel DG33FB | 4 GB Corsair 6400C5G DDR2-800Mhz | XFX 8800GTX | CM Extremepower 600W | 250GB Seagate HDD | Lite-ON 1635S DVD RW | Logitech MX-518 | Zalman RS6F | APC RS 800 |
Stalker is offline
Old 02-10-2006, 02:56 AM   #5 (permalink)
Yes, i've formatted all the space/the entire drive.....the disk management just isn't showing the rest of the space, i've also tried with Norton Partition Magic... it's just showing 31.2GB of space..
Old 02-10-2006, 10:07 AM   #6 (permalink)
gooby pls
Third Eye's Avatar
Use partition magic and get back the free space by creating a new disk.
Old 02-10-2006, 10:11 AM   #7 (permalink)
SE><IE
Posts: n/a
open the cabinet and make sure there's "80 GB" written. Alternatively get your HD to yuor buddy's PC and then check.
Old 02-10-2006, 06:34 PM   #8 (permalink)
Of course....there's 80GB written.... I've used it B4... this all happened after a windows crash (requiring reinstallation of OS) -> inaccesible harddisk (when installed windows on another HDD nd tried to access this 1) -> data recovery -> format
Initially Norton Partition Magic was showing two partitions (total space 80GB)... then i deleted all of them ... then formatted ..... result was 31.2 GB
Old 02-10-2006, 07:17 PM   #9 (permalink)
Stalker's Avatar
^^try Acronics Partition Expert or Partition Magic..........they may detect the inaccessible disk space
Stalker is offline
Old 07-10-2006, 11:52 AM   #10 (permalink)
tht dint work...
Old 07-10-2006, 03:07 PM   #11 (permalink)
Mr India Did U See The Jumper Setting Because In Jumper Setting U Can Restrict Ur Hdd To 32gb , So See It.good Luck.
rocksmart1 is offline
Old 10-10-2006, 07:06 PM   #12 (permalink)
I too think the problem is due to Jumper setting....
Hey tharkiman Reply even if you have already figured out that.
dabster is offline
Old 10-10-2006, 07:40 PM   #13 (permalink)
shashank4u's Avatar
how can we restrict hdd capacity to 32 gb with jumper settings
plz let me know.
Be like a postage stamp-stick to one thing until you get there.
shashank4u is offline
Old 10-10-2006, 08:14 PM   #14 (permalink)
jz2linkinpark's Avatar
format your drive again
(\__/)
(='.'=)This is Bunny. Copy and paste bunny into your
(")_(")signature to help him gain world domination.
jz2linkinpark is offline
Old 10-10-2006, 08:40 PM   #15 (permalink)
-The BlacKCoaT Operative-
Rollercoaster's Avatar
plz let me know.
read the manual..
there is a jumper pin set.. which u can short using a jumper.. to enable smaller size.. this feature is for older boards which can recog new drivers
Rollercoaster is offline
Old 11-10-2006, 03:05 AM   #16 (permalink)
I Always Prefer 1080p
techtronic's Avatar
Cool Re: HDD Problem
The jumper restriction was actually due to the fact that the FAT 32 file system cannot have a partition size of more than 32 GB.
It was actually enabled by a jumper setting for Windows 95/98
Seagate HDDs have this setting by putting the jumper in fourth slot under jumper setting (Correct me if am wrong)
I dont know about other HDDs
techtronic is offline
Old 11-10-2006, 11:06 AM   #17 (permalink)
Welcome To The Jungle
sysfilez's Avatar
make sure it is set to master or slave, jus chek whether u have 2 jumpers if yes remove one. use a win xp bootable disc and create partitions/format.
__________
Originally Posted by Rollercoaster
read the manual..
agree with rollercoaster.
__________
also chek whether ur mobo support large size disc.
Me n My Canon EOS 350D with EF 50mm f1.8
sysfilez is offline
Old 15-10-2006, 12:18 AM   #18 (permalink)
check ur jumper settings.....we can limit capaity to 32GB using jumper settings
ajeesh is offline
Old 21-10-2006, 04:48 PM   #19 (permalink)
ok i'll try this.....n tell u
__________
k cool.......everythins alrite now/////thnx ppl
Old 21-10-2006, 10:27 PM   #20 (permalink)
32 Gb jumper setting was implemented because some old motherboards's bios cant reconize Hard Disk above 32 GB. This setting makes atleast a 80 gb hdd work with those motherboards despite losing more than 60% of space.
jeetu is offline
Old 21-10-2006, 10:35 PM   #21 (permalink)
sourav's Avatar
check jumper settings of your harddisks
We must accept finite dissapointment. But we must never loose infinite hope.
sourav is offline
Old 21-10-2006, 11:13 PM   #22 (permalink)
sree_shan's Avatar
first check the jumper settings ... and if u finds everything is fine then ....
goto the computer management -> disk management ....
and check whether there is any free space showing .... if so create new drives.....
=>@ sree_shan @<=
"I do not fear computers. I fear the lack of them..."
sree_shan is offline
Old 22-10-2006, 08:30 AM   #23 (permalink)
yea......thanxx every1.. the problem has been resolved
