Old 30-09-2006, 07:53 PM   #1 (permalink)
Default XP wont Install
Hello Friends.
I have a K8M Neo Motherboard + AMD 64 3000.
I am not able to install Windows XP , maybe my motherboard has some fault, it was under warranty, sent it to the service center, they say its fine, but when i boot windows xp from the CD, it gives me an error.
The service center says that my hard disk is bad, i have checked it with other motherboards the hard disk seems fine.
Any Ideas where the problem cud be.
BirBal.
www.techbirbal.com -- India's Only Engineering Communtiy Portal.
techbirbal is offline
Old 30-09-2006, 08:00 PM   #2 (permalink)
slugger's Avatar
Default Re: XP wont Install
can u pleaseqoute the error message that your comp throws up. will be helpful
slugger is offline
Old 30-09-2006, 08:04 PM   #3 (permalink)
samrulez's Avatar
Do u have the proper XP CD, Optic Drive, and booting option??
Sam :D Rulez :lol:
samrulez is offline
Old 30-09-2006, 08:07 PM   #4 (permalink)
yes i have the proper CD, and a good DVD writer
All things work properly on a diff PC
The message thrown is "Cannot copy some .sys file"
Old 30-09-2006, 10:46 PM   #5 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
Check the cd on other comp
wizrulz is offline
Old 30-09-2006, 10:50 PM   #6 (permalink)
Commander in Chief
QwertyManiac's Avatar
Well, I got 2 DVD ROMS and one installs w/o errors while the other says this file or that file missing midway. So you can see the problem right?
Harsh J
www.harshj.com
QwertyManiac is offline
Old 03-10-2006, 06:53 PM   #7 (permalink)
try it after updating your bios
ajay_sparklingboy@yahoo.c is offline
Old 04-10-2006, 02:17 AM   #8 (permalink)
nishant_nms's Avatar
Nothing yaar just a media problem get another CD and try. Also clean ur DVD ROM using a lens cleaner
nishant_nms is offline
Old 04-10-2006, 09:58 PM   #9 (permalink)
Tanmay's Avatar
You definately have got a scratched disk there.Replace it with another pirated copy
Tanmay is offline
Old 04-10-2006, 11:13 PM   #10 (permalink)
change RAM
let me know
Jitin was Here.
Jitin is offline
Old 05-10-2006, 05:34 PM   #11 (permalink)
kumarmohit's Avatar
ROTFL
Its surely a crappy disk man
kumarmohit is offline
