Old 27-09-2006, 08:54 PM   #1 (permalink)
Default gaming pc
helooo frds this is akhilesh frm mumbai i wnt to buy a gaming pc mostly for for gaming and surfing only i want a pc tp play cs and nfs undergroung and other games plzz quote the price max 30000 rs
__________
plzz yarr any help me
Last edited by hackers2005.3721; 27-09-2006 at 08:54 PM. Reason: Automerged Doublepost
hackers2005.3721 is offline
Old 27-09-2006, 09:23 PM   #2 (permalink)
samrulez's Avatar
Default Re: gaming pc
AMD Athlon64 3500+ ...........6k
ASUS A8N.VM....................4k
XFX 7600GS.or 7600GT..................7k/12k
Transcend 512X2.............5000
Seagate 160-200GB SATA (II) HDD...........4k (200GB)
Lite-on 1650.....................2.2k
caby+SMPS................2000
keybo+mouse................1000
Sam :D Rulez :lol:
samrulez is offline
Old 01-10-2006, 09:23 AM   #3 (permalink)
jz2linkinpark's Avatar
sams config is good, but i'd reccomend:
Athlon64 X2 3600+ Rs. 6,900
(\__/)
(='.'=)This is Bunny. Copy and paste bunny into your
(")_(")signature to help him gain world domination.
jz2linkinpark is offline
Old 02-10-2006, 01:19 AM   #4 (permalink)
Smile Re: gaming pc
if u wanna play medium Graphics games like underground & with low-medium settings den u can cut down some bucks on 7600GT & can go for some of d earliers basic cards... u would save around 8K.
for 5k, you should eye a 6600GT.
For 15k, you get a 7900GS, 17k for 7900GT, look out for a 7900GTO as well, 7900GTX is out of budget and looses to a 1900XT within the same price range.
OR juz wait for 2-3 months for some new Graphics cards supporting directx10.
After 3-4 months for 15k you will get a 7950GT and if you are extremely lucky a 1900XT for a tad more, or you might get a 1800XT around 15k then.
& even buying normal keyboard & mouse would not be more den 450-500 bucks.
Intel Pentium triple3core 5.5Ghz intel original D502 GCCL Mobo 50 Gb DDR-4RajaPathar 2048Mhz 40 TBHDD EX12500XFX2GbDisplay SonyBlueRay+/-RW80.5GB
return_of_vengeance is offline
