Old 24-09-2006, 05:47 PM   #1 (permalink)
Default Can't delete file on USB Drive
Hi!I use a Transcend JetFlash drive 512MB for my backup and carrying files.A few days back,while working in a cyber cafe,the comp rebooted suddenly and i was unable to eject the drive i.e remove it properly, and from then on i am seeing a file with a name containing random charcters(size 0 KB).This file can't be deleted.I have run a scandisk(windows proprietary and Norton Disk Doctor) and yet am unable to delete the file.On trying it says:Can't access the file named...
I have also run a virus check on the drive and results are negative.
Kindly suggest away in which i can delete the file.
a ship is safest at the harbour but thats not what its built for!
serendipiti is offline
Old 24-09-2006, 05:55 PM   #2 (permalink)
-- No Easter Eggs here --
hemant_mathur's Avatar
Default Re: Can't delete file on USB Drive
If u can then try to format the drive
E6850 3.0 Ghz, 4gb 667 Mhz RAM, Asus p5n Esli Mobo, Nvidia 8600GT 512mb, 400gb WD HDD, Samsung Syncmaster 920NW, Vista x64
hemant_mathur is offline
Old 24-09-2006, 06:13 PM   #3 (permalink)
well formatting will the last option...will try everything else b4 formatting
Old 24-09-2006, 06:23 PM   #4 (permalink)
speedyguy's Avatar
its just a matter of 512mb dude...just backup ur data in ur hdd n format it...not dat a big issue...i think there is some conflict wit winfile recognisation...so windows not able 2 access it n u cant access ur thumb drive in non win os like dos or so....so format it...my advice
Cheers!
No Pain...No Gain
speedyguy is offline
Old 24-09-2006, 10:07 PM   #5 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Try Unlocker to delete the file, otherwise try to remove the file from DOS or Linux
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 24-09-2006, 11:14 PM   #6 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
back up imp data ..and format simple....
wizrulz is offline
Old 25-09-2006, 12:00 AM   #7 (permalink)
dIgItaL_BrAt's Avatar
Use Unlocker
EDIT:Vishal already posted that solution.
dIgItaL_BrAt is offline
Old 25-09-2006, 12:18 AM   #8 (permalink)
hmmmmmmmmmmmmm's Avatar
Originally Posted by dIgItaL_BrAt
Use Unlocker
You know something? I could have gone the rest of my life without knowing that.
hmmmmmmmmmmmmm is offline
