Old 23-09-2006, 08:23 PM   #1 (permalink)
You'r Born Free
int86's Avatar
Arrow What was that
As always i switched my Pc. It has two XP and one Win98 partition. I usually I work on firsrt Xp partition.
After welcome screen I saw blank screen with mouse pointer only. Several attemps to boot in both Xp partition failed, then I tried Win98 with sucess. when I restarted everything was OK.
What was that, during disk cheking some BOOTEX.log file was mentioned.
# Money, Beauty and Configration has no ends.
# Life is like game sometimes. Play it or loose it. But keep the spirit of game.
http://en.wikipedia.org/wiki/Right_to_Information_Act
int86 is offline
Old 23-09-2006, 08:26 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: What was that
Bootex.log is a file created by chkdsk.exe when it is run
Harsh J
www.harshj.com
QwertyManiac is offline
Old 23-09-2006, 11:10 PM   #3 (permalink)
Try bootng in safemode by pressing F8 at boot menu
If it boots in safemode OK then you will need to uninstall newly installed software
Could probably help ya
Mayur is offline
Old 23-09-2006, 11:18 PM   #4 (permalink)
You'r Born Free
int86's Avatar
As I already told everything is Ok. I just wanted to know what and how that happenned
int86 is offline
Old 23-09-2006, 11:26 PM   #5 (permalink)
Commander in Chief
Its best not to run a dual boot with 98 and XP, sucks. But I really dont know what kind of system file interference took place.
Harsh J
www.harshj.com
Old 24-09-2006, 02:01 AM   #6 (permalink)
Super Hero - Super Powers
n2casey's Avatar
Why shud we discuss if everything is fine.
n2casey is offline
Old 24-09-2006, 05:25 PM   #7 (permalink)
You'r Born Free
int86's Avatar
Sorry to say but I dont care what a new user says.
I recently changed CMOS battery. I got the new battery from an watch shope. I checked battery, its fine.
One major point I got. whenever I starts sys it says to press F2 to reset CMOS setting, then only comes the blank screen with mouse pointer.
After i follow the privious step i.e. to boot in 98 then to Xp back.
So what is happening. battery is ok , i checked it with a 3v bulb.
int86 is offline
Old 24-09-2006, 06:00 PM   #8 (permalink)
-- No Easter Eggs here --
hemant_mathur's Avatar
looks like some mobo prob to me ..... still try replacing the battery and get back here
E6850 3.0 Ghz, 4gb 667 Mhz RAM, Asus p5n Esli Mobo, Nvidia 8600GT 512mb, 400gb WD HDD, Samsung Syncmaster 920NW, Vista x64
hemant_mathur is offline
Old 24-09-2006, 11:19 PM   #9 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
dude a mobo problem....the capacitor ...to be specific.....its taking up the battery power..so u haev to replace it......ur mobo need a mechanic.....repair cost mi8 be near to 300.......if i am ri8..i had same problem..with my old mobo...
wizrulz is offline
Old 25-09-2006, 04:10 PM   #10 (permalink)
You'r Born Free
int86's Avatar
@wizrulz
I check the battery frequently, its Ok. If something on mobo is draining the power of battery then battery would hve drained out(i.e. got dischared). But since battery remains ok, shows that nothing is draining CMOS bttery. thanx for ur input.
int86 is offline
