Old 23-09-2006, 02:29 PM   #1 (permalink)
Default BIOS Password Problem
I have intel 915GAV motherboard. I installed supervisor passsword in the bios and restricted users from accessing it. I forgot the bios password, so i took out the jumper and battery then installed them again. Now I can access the bios but I cannot install the supervisor password as it is already installed and i dont know the password. Please help me how can I remove the old supervisor password and install a new one.
ty
n.regmi is offline
Old 23-09-2006, 03:30 PM   #2 (permalink)
Come get Some
DukeNukem's Avatar
Smile Re: BIOS Password Problem
Hye Bro.
first Check your Board Manual for any jumper setting of switch setting to remove the forgetten Passwords/wrong bios setting.
if its bit confussing.
remove the battery of the motherboard for a while (2-5Min), it will set the default bios settings
happy
DukeNukem is offline
Old 23-09-2006, 03:33 PM   #3 (permalink)
Default Re: BIOS Password Problem
i removed the battery for 1 hour, the password is still installed lol.
n.regmi is offline
Old 23-09-2006, 06:57 PM   #4 (permalink)
nishant_nms's Avatar
look out for clear CMOS jumper in the manual and then shot tem for a while using a tester. It should be near the CMOS battery
nishant_nms is offline
