Old 22-09-2006, 12:07 PM   #1 (permalink)
ync
Default LAN Problem
I have a laptop and a desktop computer both are running Windows XP. I wanted to connect them via LAN so I bought a Silan SC92031 PCI LAN Card (for the desktop PC) and a RJ45 Cable (Laptop has built-in LAN). I installed the card's driver and XP created a connection automatically. The problem is that a balloon pops up showing "Network cable is unplugged." even when the network cable is properly plugged. Please help.
ync is offline
Old 22-09-2006, 06:07 PM   #2 (permalink)
varkey's Avatar
Default Re: LAN Problem
u need a crossed lan cable not the usual cable.
Intel Core 2 Duo E6300 @ 1.86 GHz | Intel DG965WH | 2x1GB DDR2 667 MHz Transcend | Seagate 320 GB SATA II | Sony DW-Q120A | Samsung 940bw 19" LCD
varkey is offline
