| Forum |
#1 (permalink) |
We must accept finite dissapointment. But we must never loose infinite hope. |
#2 (permalink) |
No pain....No gain
See this: http://www.maplin.co.uk/Module.aspx?...PTERS&doy=21m9. Is this u r looking for.
--------------------------------------------------- Faith is the boast of a man who is too lazy to investigate. --------------------------------------------------- |
#3 (permalink) |
can you give me a step by step guide. I want to make it my self.
Thanx
#4 (permalink) |
Alive Again...
My MotherBoard has 20 Pin
Recently My SMPS got short So i bought New SMPS in that their was 1 Wire Jointed which was converting 20pin into 24pin I removed that wire & my SMPS got converted into 20Pin U can buy that Small Wire from Computer Accessories Shop |
#5 (permalink) |
Back to l33ching :)
Location: Latitude: 22° 32' North. Longitude: 88° 22' East
even my msi mobo has 24 pin slot, but am using a 20pin smps w/o ne probs,
@sourav..do chek ur mobo manual, mayb it supports 20pins
Whenever you find yourself on the side of the majority, it is time to pause and reflect ~ Mark Twain |
#6 (permalink) |
my mobo do support 20 pin but i want to make it 24 pin to get full performance from it. and i want to make it my self, ok how much the wire mentioned up, can cost.
#7 (permalink) |
You can buy a 20-pin to 24-pin converter cable. It costs around Rs. 150/- and easy to install with all the standard sockets. Just attach 20-pin side of the converter to your existing 20-pin smps cable. The other end of the converter is 24-pin so you wont have to play with any wires.
#8 (permalink) |
Back to l33ching :)
hmmm...so wil usin 24 pin improve my pc performance? can u confirm this..
#9 (permalink) | |
V.Prem Kumar |
#10 (permalink) |
but I heard that some mobos get heated more if we use a 20 pin in place 24 pin, my mobo do support 20 pin and it is working on that 20 pin wala
| Bookmarks |
| Thread Tools | |
| Display Modes | |
