Old 22-09-2006, 01:44 AM   #1 (permalink)
Default Any S/w That Displays Cpu Temp?
HEY GUYS I HAVE P-4 WITH 512*2 ddr-2 RAM, MY CPU TEMP IN bIOS REMAINS 64 DEGREES AT 30 DEGREE ROOM TEMP...
I KNOW THAT BIOS SHOWS MAX TEMP DUE TO 100% cpu USAGE.
so CAN ANY 1 SUGGEST ME SOME NICE SOFTWARE TO CHECK MY cpu TEMP WHILE USING DIFFERENT GAMES & 3D EDITORS?????
Intel Pentium triple3core 5.5Ghz intel original D502 GCCL Mobo 50 Gb DDR-4RajaPathar 2048Mhz 40 TBHDD EX12500XFX2GbDisplay SonyBlueRay+/-RW80.5GB
return_of_vengeance is offline
Old 22-09-2006, 01:47 AM   #2 (permalink)
sourav's Avatar
Default Re: Any S/w That Displays Cpu Temp?
just go and search internet and you will many software (just start googling). There is a software named Speed Fan, it is a really really god software.
We must accept finite dissapointment. But we must never loose infinite hope.
sourav is offline
Old 22-09-2006, 02:05 AM   #3 (permalink)
i want names of some s/w dat shows d real temp not making just randoms,.....
Old 22-09-2006, 08:43 AM   #4 (permalink)
nishant_nms's Avatar
use motherboard monitor 5
nishant_nms is offline
Old 22-09-2006, 11:53 AM   #5 (permalink)
t3h g04t
teknoPhobia's Avatar
SpeedFan
technologically challenged.
teknoPhobia is offline
Old 22-09-2006, 02:21 PM   #6 (permalink)
samrulez's Avatar
Speed Fan.....
+NO config required
-Dosen't alarm...when the temp is outta control
MotherBoard Monitor
+Alarms.....shows all info
-a bit of config required...
Sam Rulez
samrulez is offline
Old 22-09-2006, 05:51 PM   #7 (permalink)
Tux Fan
shaunak's Avatar
if your mobo's from intel you can use the monitoring tool. head over to intel's website to get it.
Cheers
Shaunak
Feel free to PM/email me.
shaunak is offline
Old 22-09-2006, 06:42 PM   #8 (permalink)
deathvirus_me's Avatar
For all - Speedfan
deathvirus_me is offline
Old 22-09-2006, 06:50 PM   #9 (permalink)
dOm1naTOr's Avatar
speedfans displaying the real temp nd no fake like return_of_vengeance said. Its really nice for all obos nd config.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
