| Forum |
#4 (permalink) |
DDR2 800 is not useless, something expensive can't be called useless.
DDR2 667 value RAM will be around 11-12k, expensive RAM or good RAM as you say like Corsair XMS or Kingston HyperX will be around 20k or more. Rather get 4GB DDR2 533/667 Value at this point of time after a few months.
Core i7 2600k|Gigabyte P67A UD4 B3|Corsair XMS3 2x4GB|HD6970|Coolermaster SilentPro 850M|Coolermaster HAF 932|Audioengine AE5|Samsung Galaxy S|Samsung Galaxy Tab 3G|Blackberry Curve 8520 |
#5 (permalink) | |
The High 5 Flyer
Trust me dhawald, choose any.... 667 or 800 depends upon your budget (and mobo ofcourse), but go for only Corsair. Believe me its THE best ram around. It rocks. Not vey costly. Run a survay on the net and you will know what I mean when I say Corsair rocks. The next best option I would suggest is Kingston. Another damn good brand.
sam9s NAS Project! powered by Unraid! (Corrected!) sam9s HTPC Project! powered by XBMC! sam9s i7 Powered by Sandybridge! My XBMC Collection Last edited by sam9s; 24-10-2006 at 02:34 PM. |
#6 (permalink) |
Corsair is the best but not as such better than other. You won't notice much of a difference, although if corsair is compatible with your mobo and exceeds your budget only slightly and you find a overclockable chip, then get it, else don't. D9 is ocable.
I would any day get Transcend over Kingston.
#8 (permalink) |
I have a couple of 1GB sticks of transcend 667... one week old wanna dispose off cos I'm getting ddr2 1000 in a few days. PM me if you want them. Will give u for 1k less than market price. These transcends are based on micron d9gmh which happens to be one of the best chips currently available and do 850 @ 4-4-4 @2.2V easily.
C2D E8400@3.8, P5N32-E SLI, 2GB Cellshock DDR2 1000(4-4-4), 8800 Ultra SLI, 2.7TB storage, CM Stacker 830, TT 1200W, Dell 2005FPW, Lots of Audio HW. |
#10 (permalink) | |
#12 (permalink) |
Bayerische Motoren Werke
Kingston is good,get a 2 X 512 DDR RAM @533MHz
Total cost is about Rs 4200-4300 from Nehru Place.
File not found. Should I fake it? (Y/N) |
#13 (permalink) | |
The High 5 Flyer
#14 (permalink) |
the kingston 1gb ddr2 800 mhz are very very expensive around 8-9k (not sure)
Intel Core 2 Duo E6300 | Gigabyte 945 GM S2 |2X1 GB DDR2 transcend @ 667 mhz| Samsung 740N (17in)| 200GB Seagate SATA HDD | LG H10N | logitech MX 518 | Steelpad 5L | Philips HP 805 |
#19 (permalink) |
If its ddr2, transcend is way better than kingston or corsair. You are guaranteed micron d9 chips. Here's the proof
http://anandtech.com/memory/showdoc.aspx?i=2862&p=2
#20 (permalink) | |
The High 5 Flyer
http://www.xbitlabs.com/articles/mem...dr2-800_8.html |
#21 (permalink) |
^^ROFL Transcend Jetram is valueram and priced less than corsair valueselect. XMS doesn't even come into the picture. The ram in that article is XMS 6400C4 which sells in india for 20.5K+tax for a 2GB kit. That price is ridiculous. The transcend jetram i'm talking about here sells for around 12-13K all inclusive . There's no comparison between the two. Also its lame to be buying a 1GB high end kit anymore.
If one really wants good ram, its best to import. I imported my PC2 8000(1GHz) CL4 rated Cellshocks for less than that amount all inclusive sitting here in india . Corsair has nothing... absolutely nothing that even comes close to this RAM. The only thing thats about equal in performance is stuff from Teamgroup.
#22 (permalink) | |
The High 5 Flyer
#23 (permalink) |
^^The transcend easily does around 880 or so with tight 4-4-4 timings. Or so my pair did atleast before I sold them off. Corsair valueram 1GB sticks are around 7K all inclusive. Transcend is around 1K cheaper and a much better deal. They are guaranteed micron D9GMH chips which are used in most DDR2 800 low latency (4-4-4) kits.
As for my kit, I bought the new pair online and had it shipped via DHL. These are Micron D9GKX chips and the best ram in the business as of now.
#24 (permalink) |
The High 5 Flyer
Well if tran can go up to 880, my next upgrade for 800 Mhz would be it... but frankly I cannt find any review online which gives me Trans as an OC RAM. Even Kingston doesnt qualify as a good OC ram. I can present n reviews where Corsair and Mushkin are projected as best OC ram. My next pick was Mushkin 1 GB 800 which can cross 1.2 OCed. Let me RnD on Trans as well.........good to have a healthy discuesion.
#25 (permalink) |
Its not overclockin ram hehe... its value ram that overclocks a bit cos it uses good ICs thats all. Corsair XMS2 800C4 and 1066C5 are good but if you really wanna spend that much, you are better off with Team Xtreem or Cellshock or GSkill. The speed hardly matters... its the latency at the speed thats of paramount importance. 4-4-4@1000 is faster than 5-5-5@1100. My ram will go beyond 1300 if i loosen the latencies to 5-5-5 and push a bit of voltage but I get better scores at 4-4-4@1050, 2.2V than higher latencies at higher speeds. I still haven't found the maximum of these thingies... gotta try out sometime.
#26 (permalink) | |
I plan to import the graphic card & ram for my new PC |
#27 (permalink) |
^^check www.memoryc.com. Customs ain't an issue as you can ask the guys to mark it at 50$ or something. I was charged 800 bucks customs out of which 300 was their clearing charge. DHL cleared it and I just paid DHL. The duty rate for computer hardware is 21.4%.
#28 (permalink) | |
The High 5 Flyer
| Bookmarks |
| Thread Tools | |
| Display Modes | |
