Old 20-09-2006, 07:22 PM   #1 (permalink)
Lin Win Mac
ruthless's Avatar
Default Trouble with Internet
I use an AMD 64 3200+Asus a8n SLI deluxegeforce 6200512 mb ram.The os is xp pro.Recently i tried to connect a modem to my pc and it kept on restarting.So i decided to get myself A broadband connection. I got Tata Indicom Broadband. It connects fine but when i disconnect a Blue screen appears and say that the computer is now restarting to prevent damage to the os.the last line says abt dumping physical memory or smthing .Is it a problem with my Mobo?it is only $months old.Plz help.
Tendancy Of A System is Always To Distort
ruthless is offline
Old 20-09-2006, 10:31 PM   #2 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
Default Re: Trouble with Internet
Update the drivers for ur LAN....
wizrulz is offline
Old 21-09-2006, 09:25 AM   #3 (permalink)
Distinguished Member
anandk's Avatar
its the fabled blue screen of death.
rt click on my comp icon > properties > advanced > startup & recovery > system failure > uncheck automatic restart. next time u get the bsod u will be able to read the cause.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 21-09-2006, 11:15 AM   #4 (permalink)
Lin Win Mac
ruthless's Avatar
I think The trouble was with Crystal Xp and Windows Blinds. I uninstalled Both of them and Now I am able to connect to internet. Hope no more problems come up. I will keep posting
ruthless is offline
Old 21-09-2006, 11:35 AM   #5 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
hey u said initially that it connects fine only has problem only when it disconnects........ and now.....
That means now u want to say that after disconnect u do not get BSOD???
wizrulz is offline
Old 21-09-2006, 01:07 PM   #6 (permalink)
Lin Win Mac
ruthless's Avatar
Well I think I got You confused.I got the connection on tuesday night and it worked fine on that day.On wednesday evening I installed crystal xp on my pc and trouble started.On wednesday BSOD came when i was disconnecting, but today I couldnt even connect to the net.So i uninstalled CXP & WinBlinds and i could connect to net without trouble. That was when i made the second post. But the problem still continued when i disconnected at today at 11:59 am.I am tring to read what BSOD say .
ruthless is offline
