Old 20-09-2006, 12:46 AM   #1 (permalink)
Post AMD 3800 X2 + good mobo combination
hi guys
i'm planning to buy a system. mainly for 3d animation and compositting.
my budget is 30000-32000 (monitor not included in budget)
the config i'm looking for is.
AMD athlon 3800 X2 dual core
"asus A8N-E" or "Asus nforce 570 ultra mcp" mobo
512 mb ddr2 (will extend to 1 gb afterwards)
256 mb 6600 gt graphics card
250gb SATA Hdd
if anybody has idea about the performance of this config..pls suggest.
also suggest if u have any othet good configuration within this budget.
thnx in advance.
praway is offline
Old 20-09-2006, 01:37 PM   #2 (permalink)
samrulez's Avatar
Default Re: AMD 3800 X2 + good mobo combination
try to get a C2D E6300 for 10k ...and a mobo 965 mobo for 6k,.......it should be more future proof.......and get atleast 1GB DDR2 ram..
Also if u r going for ASUS A8N-E u cannot use DDR2 sticks its a 939 mobo, so it has to be DDR.....
Sam Rulez
samrulez is offline
Old 20-09-2006, 02:20 PM   #3 (permalink)
get intel core2duo 6300------rs 9300/-
intel dg965ry mainboard--rs 7200/-
1gb transcend ddr2 667mhz-rs 5000/-
for graphic card go for 7300gt instead of 6600gt.
6600gt is expensive it is rs 6050 it does not match the performance of
7300gt. 7300gt is the clear winner.if you streatch the budget little longer
go for 7600gs.
zebronics 7300gt----rs 5000
zebronics 7600gs ---rs 6500
good luck------------------------------------
ramana321388 is offline
Old 20-09-2006, 04:46 PM   #4 (permalink)
get Gigabyte 965 S3 instead or atleast MSI Neo F 965
DDR2 7300GT may loose out to a 6600GT
akshayt is offline
Old 20-09-2006, 05:01 PM   #5 (permalink)
jz2linkinpark's Avatar
if i were you,i'd avoid E6300,its NOT AT ALL functional,and problems just spring up from the first minute,trust me
get either E6400 or just opt for AMD x2
(\__/)
(='.'=)This is Bunny. Copy and paste bunny into your
(")_(")signature to help him gain world domination.
jz2linkinpark is online now
Old 21-09-2006, 03:22 PM   #6 (permalink)
Hey guys,
can anyone suggest me good processor & an motherboard with a good graphics card, my budget for all the three things can extend upto 20,000 to 25,000. so please some one suggest me an good option for these things..
tokci is offline
Old 21-09-2006, 04:29 PM   #7 (permalink)
what kind of difference will you find between E6400 and 6300, not performance that is.
akshayt is offline
