Old 19-09-2006, 06:40 PM   #1 (permalink)
Default SATA HDD prob
Hello all
I got a AMD 64 bit 3000+
GA-K8N51GMF-9 mobo
512 mb ram
bought a new 160 GB Sata
booting from it
also attached is a 160 GB ATA
now the speed of SATA disk is very slow
applications take a lot of time to open
boooting is slow
Is there any problem is using ATA disk with SATA
Regards
Jitin was Here.
Jitin is offline
Old 24-09-2006, 12:04 PM   #2 (permalink)
Default Re: SATA HDD prob
Check in Device Manager if the SATA HDD is running in DMA mode ... if it is shown as PIO mode then from Device Manager Uninstall the Channel to which SATA HDD is attached and on reboot the SATA HDD should work in DMA mode at normal speeds.
suman2005 is offline
