Old 19-09-2006, 10:29 AM   #1 (permalink)
Welcome To The Jungle
sysfilez's Avatar
Question Seagate 160gb Hard Drive installation woes
Last day i bought a seagate 160gb sata hard drive, i have set it to 3gb/sec. my bios detected it properly, but my system tray shows "safely remove hardware" when i open it, it shows my new hard drive. Why is this happening?
My mobo is asus a8n-e, i have win xp sp2. my other hard drive is seagate 40gb ata and my os is installed in this.
BTW wat is dynamic drive?
Pls help guys.
Me n My Canon EOS 350D with EF 50mm f1.8
sysfilez is offline
Old 19-09-2006, 11:53 AM   #2 (permalink)
papai_mcc's Avatar
Default Re: Seagate 160gb Hard Drive installation woes
SATAII is hot-swapable.So do not worry!it is normal
View My Photo Gallery: http://the3rdeye.co.cc
papai_mcc is offline
Old 19-09-2006, 08:18 PM   #3 (permalink)
nishant_nms's Avatar
It's common with SATA 2 drives as it supports e-SATA
nishant_nms is offline
Old 24-09-2006, 12:12 PM   #4 (permalink)
If you install the NVidia IDE drivers this shows up in the system tray. If you stay with the MS IDE drivers this does nor show. I use an eSATA external HDD so for me this is very usefull when I want to disconnect the external HDD.
Please note that the nVidia IDE drivers before the latest 6.86 version were meant to be buggy so install this latest NVidia driver or use the default XP MS IDE driver.
suman2005 is offline
Old 26-09-2006, 11:12 AM   #5 (permalink)
sysfilez's Avatar
tnx everybody for answering my query.
sysfilez is offline
