Old 19-09-2006, 09:55 AM   #1 (permalink)
Default Hard disk not detected in BIOS,
I have a samsung hdd which was working fine for the last 1 year but now it is having problem and sometimes not shown up in the BIOs,the System stops booting....After successive Reboots HDD gets detected and after that the system works fine...
But when again sytem started some other time it problem of not detecting HDD comes again....
I have checked the cable it is all fine... and this problem comes when i connect it to some other computer also....
Also the F: drive is being checked every time while booting....
I have done chkdsk on alll drives... Initially had some lost chains but now all fine...
Does that mean My hard disk is dying ????
dabster is offline
Old 19-09-2006, 11:18 AM   #2 (permalink)
-- No Easter Eggs here --
hemant_mathur's Avatar
Default Re: Hard disk not detected in BIOS,
Does the hard disk make strange screeching or tick sounds ?
E6850 3.0 Ghz, 4gb 667 Mhz RAM, Asus p5n Esli Mobo, Nvidia 8600GT 512mb, 400gb WD HDD, Samsung Syncmaster 920NW, Vista x64
hemant_mathur is offline
Old 19-09-2006, 11:31 AM   #3 (permalink)
Welcome To The Jungle
sysfilez's Avatar
do u have any other hard drive on ur system?
Me n My Canon EOS 350D with EF 50mm f1.8
sysfilez is offline
Old 19-09-2006, 12:23 PM   #4 (permalink)
No audible Sounds and i don't have any other drive connected to Computer....
dabster is offline
Old 19-09-2006, 04:14 PM   #5 (permalink)
Bayerische Motoren Werke
Third Eye's Avatar
@dabster: Any bootsector in hdd ?
File not found. Should I fake it? (Y/N)
Third Eye is online now
Old 20-09-2006, 04:12 PM   #6 (permalink)
@tech_mastermind: I believe u r asking bad sectors....
Here no bad sectors on My hard disk....on all the drives...
Also If checked with the Speedfan utility it says that Spin up time is having worst value so The performance level which is shown as a bar is low....
Anybody uses speedfan ??
dabster is offline
Old 26-09-2006, 07:53 PM   #7 (permalink)
Any software tht tells the SMART parameters and checks the Hard disk status....
dabster is offline
