Old 18-09-2006, 03:53 AM   #1 (permalink)
mobilegeek's Avatar
Wink Decent Stylus(Light input device) req!
Need a decent Stylus (light input device) . I think waccom ka aata hai i guess. One of my designer friend is looking for it but as cheap as possible. not to exceed 5K. He has scanned every little bit of pattern so with the help of stylus it will be a lot easier as he can draw the pattern straight away on the screen. I dont know much about these.. If you can which one to buy that will be helpfull. thanx regards
mobilegeek is offline
Old 18-09-2006, 07:20 AM   #2 (permalink)
 Macboy
goobimama's Avatar
Default Re: Decent Stylus(Light input device) req!
Wacom tablet (4x6) costs arnd 4.5k in India. The local apple corner has it. I don't know of anyone else. Also try the official wacom dealer (through email)
sengine@wacomindia.com ; sengine@giveatry.com
WEBSITE : www.wacomindia.com
I'm like a bird... :)
goobimama is offline
Old 18-09-2006, 04:32 PM   #3 (permalink)
mobilegeek's Avatar
Thanx for replying .. Is there any other than that?
Old 19-09-2006, 02:40 PM   #4 (permalink)
 Macboy
goobimama's Avatar
Wacom is the best to my knowledge.... There are the usual iBall and others but their quality is not upto mark....
Old 20-09-2006, 07:39 PM   #5 (permalink)
Tux Fan
shaunak's Avatar
I ball ones are cheap and decent. but you wont get professional quality though. the cost about 2K [for tablet] and 2.8-3K for pen.
Cheers
Shaunak
Feel free to PM/email me.
shaunak is offline
Old 22-09-2006, 03:33 AM   #6 (permalink)
mobilegeek's Avatar
I think it will be wacom them,
thanx for replying guys! keepup the good work
regards
