Hi friends... im using
. I use Nero 2 burn the disks. Recently im facing a problem. When ever i try 2 write the DVD's its giving the following error and stopping the burning process....
Windows 2000 5.0
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0002), size=45056 bytes, created 7/17/2002 9:20:56 AM
ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 10/26/2004 6:35:34 PM
Nero Version: 6.6.0.15
Internal Version: 6, 6, 0, 15h
(Nero Express)
Recorder: <SONY DVD RW DW-Q28A> Version: KYS3 - HA 0 TA 1 - 6.6.0.15
Adapter driver: <atapi> HA 0
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <SONY DVD RW DW-Q28A >Version: KYS3 - HA 0 TA 1 - 6.6.0.15
=== Scsi-Device-Map ===
DiskPeripheral : SAMSUNG SV2044D atapi Port 0 ID 0 DMA: On
CdRomPeripheral : SONY DVD RW DW-Q28A atapi Port 0 ID 1 DMA: Off
CdRomPeripheral : NERO IMAGEDRIVE2 2.26 imagedrv Port 2 ID 0 DMA: Off
=== CDRom-Device-Map ===
SONY DVD RW DW-Q28A E: CDRom0
NERO IMAGEDRIVE2 F: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 73400320 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 503MB (515572kB)
Free physical memory: 163MB (167136kB)
Memory in use : 67 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
14.9.2006
ISO compilation
9:17:14 AM #1 Text 0 File Isodoc.cpp, Line 6314
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : TRUE
Multisession type: : Start multisession
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
9:17:14 AM #2 Text 0 File Reader.cpp, Line 127
Reader running
9:17:14 AM #3 Text 0 File Writer.cpp, Line 122
Writer SONY DVD RW DW-Q28A running
9:17:14 AM #4 ISO9660GEN -11 File geniso.cpp, Line 3309
First writeable address = 0 (0x00000000)
9:17:15 AM #5 Text 0 File Burncd.cpp, Line 3231
Turn on Disc-At-Once, using DVD media
9:17:15 AM #6 Text 0 File DlgWaitCD.cpp, Line 269
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 579199 (128:42.49, 1131MB)
9:17:15 AM #7 Text 0 File DlgWaitCD.cpp, Line 281
Write in overburning mode: NO (enabled: CD)
9:17:15 AM #8 Text 0 File DlgWaitCD.cpp, Line 2477
Recorder: SONY DVD RW DW-Q28A, Media type: DVD-R
Disc Manufacturer: TYG02 -
Disc Application Code: 64, Disc Physical Code: 193
9:17:15 AM #9 Text 0 File DlgWaitCD.cpp, Line 447
>>> Protocol of DlgWaitCD activities: <<<
9:17:15 AM #10 Text 0 File ThreadedTransferInterface.cpp, Line 830
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 579200 (579200) = #579200/128:42.50
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 579200 blocks [SONY DVD RW DW-Q28A]
9:17:15 AM #11 Text 0 File ThreadedTransferInterface.cpp, Line 1043
Prepare recorder [SONY DVD RW DW-Q28A] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc not fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 1186201600, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
579200 | lead-out | 1 | 0x41 | 0x00
9:17:15 AM #12 Phase 24 File dlgbrnst.cpp, Line 1832
Caching of files started
9:17:28 AM #13 Text 0 File Burncd.cpp, Line 4116
Cache writing successful.
9:17:28 AM #14 Phase 25 File dlgbrnst.cpp, Line 1832
Caching of files completed
9:17:28 AM #15 Phase 36 File dlgbrnst.cpp, Line 1832
Burn process started at 6x (8,310 KB/s)
9:17:29 AM #16 Text 0 File ThreadedTransferInterface.cpp, Line 2643
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
9:17:29 AM #17 Text 0 File DVDR.cpp, Line 2357
Recording mode: Sequential Recording Mode for Multisession
9:17:29 AM #18 Text 0 File Mmc.cpp, Line 21663
Set BUFE: Power-Burn -> ON , Adapt writespeed to disc : ON
9:17:29 AM #19 Text 0 File DVDR.cpp, Line 2511
Start write address at LBA 0
DVD high compatibility mode: Yes
9:17:29 AM #20 Text 0 File Cdrdrv.cpp, Line 8821
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 5
Disc Size: 120 mm, Maximum Rate: 10.08 Mbps (2 h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 0 h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Start sector number of the current Border-Out: 0 h
Start sector number of the next Border-In: 0 h
Media Specific [16..63]:
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
9:18:41 AM #21 SCSI -1106 File Cdrdrv.cpp, Line 1436
SCSI Exec, HA 0, TA 1, LUN 0, buffer 0x0B540000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x73
Sense Qual: 0x03
CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x73 0x03
9:18:41 AM #22 CDR -1106 File Writer.cpp, Line 311
Power calibration error
9:18:41 AM #23 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
9:18:41 AM #24 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
9:18:41 AM #25 Text 0 File DVDR.cpp, Line 2749
EndDAO: Last written address was -1
9:18:41 AM #26 Phase 133 File dlgbrnst.cpp, Line 1832
Writing short lead-out
9:18:41 AM #27 SCSI -1176 File Cdrdrv.cpp, Line 1182
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x72
Sense Qual: 0x04
CDB Data: 0x5B 0x01 0x02 0x00 0x00 0x03 0x00 0x00 0x00 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x72 0x04
9:18:41 AM #28 CDR -1176 File WriterStatus.cpp, Line 167
Session fixation error
9:18:41 AM #29 TRANSFER -24 File WriterStatus.cpp, Line 167
Could not perform end of Disc-at-once
9:18:41 AM #30 Phase 38 File dlgbrnst.cpp, Line 1832
Burn process failed at 6x (8,310 KB/s)
Existing drivers:
File 'Drivers\CDR4_2K.SYS': Ver=8.0.0.212 , size=2432 bytes, created 5/20/2006 2:46:24 AM
File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=2560 bytes, created 5/20/2006 2:46:24 AM
File 'Drivers\ASPI32.SYS': Ver=4.71 (0002), size=16877 bytes, created 7/17/2002 8:53:02 AM
File 'Drivers\PXHELP20.SYS': Ver=3.00.11B, size=46080 bytes, created 5/17/2006 1:53:54 AM (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=5.00.2195.6699, size=86672 bytes, created 6/18/2003 12:00:00 PM (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
But when i try with cd's its fully working... can any one tell me the solution plz... thanks in advance.....
