Old 16-09-2006, 07:48 AM   #1 (permalink)
Default Sound quality is poor when I play DVD
Hello Everyone,
I have PC with WinXP SP2 with Intel D915GLVG chipset....I have SONY DVD burner...
The problem: When I play any DVD Movie sound volume is poor and I couldn't increase volume of the sound...I use normal 2 way speakers..This problem is not comming when I play music i mean mp3 and dat..
I use DivX, nero showtime, windows media player, real player for DVD movies..
Any information provided is highly thankful.
Dongay Rajasekhar Panda is offline
Old 16-09-2006, 09:30 AM   #2 (permalink)
q3_abhi's Avatar
Default Re: Sound quality is poor when I play DVD
Install k-lite codec pack .
Download here : http://www.free-codecs.com/download_...hp?d=2263&s=95
C if the problem persists..
Fragging is the key to Success!!!!!
My blog : http://q3abhi.wordpress.com
q3_abhi is offline
Old 17-09-2006, 01:25 AM   #3 (permalink)
brother dongay how about power DVD player doesn't it work with you ?//
any how whay don't you try to install the codec pack which (q3_abhi) has suggested you and i hope your problem get solve ..
by the way i believe we have done fragging but still there is a problem ...
fibermanco is offline
Old 17-09-2006, 11:33 AM   #4 (permalink)
coolsunny's Avatar
if u r playing pirated movie DVDs such as 5 in one,then it is normal.they compromise with sound quality so to store more videos.
u can just make the volume fullest & turn on subtitle.
AMD X2 260, GA M68MT-S2P, Gskill RipjawsX 4GB, 500Gb Seagate, Cooler Master eXtreme Power Plus 600W, Altec Lancing atp3, Samsung B2230 TFT, Numeric Digital 600 EX-C UPS.
coolsunny is offline
Old 28-09-2006, 03:12 PM   #5 (permalink)
Desperado's Avatar
Unhappy Sound prblem playin dvd/cd with sony dvd RW
Well long story short.. whenever i play a dvd / cd with my sony dvd Rw the sound kind of echoes, the picture is slightly slower, the sound blurs...
the blurry sound is like "kissing sounds" .. it happens only if i play it on my dvd player.. BUT WHEN I PLAY A MOVIE SAVED ON MY HARDDRIVE .. it works perfectly fine..
HELP people.. i posted this earlier too but in the wrong section.. sorry..
Friendly Neighbourhood,
Shahid
Desperado is offline
Old 05-10-2006, 10:23 PM   #6 (permalink)
baccilus's Avatar
Hi Dongay. I had the same mobo till a week ago, and i had the exact same problem, even with 100% original DVD's. It must be sounding like pur...pur..purr. I mean something like that.
Soln.: For increasing the volume, use K-lite codec pack and use the boost sound option.
For the disturbance in the DVD: I don know. i am not having this problem in my new mobo.
Appreciate me now and avoid the rush!!
i5 2500K || 8GB DDRIII 1600 MHz RAM || Zotac GTX560Ti || Samsung 2233sw || Corsair GS600
baccilus is offline
