Old 15-09-2006, 03:45 PM   #1 (permalink)
boomstation2's Avatar
Post Suggest ASUS mobo + AMD 64 fx best combination
Hi all, This is my first post. Myself from Mumbai.
Lookin at the Future....i thought of Upgrading my pc.
Guys n Expert Techies pls Help me to suggest few of my req. Currently i wanna upgrade my PC (P III, 815e, 128 mb) with some good
ASUS Mobo + AMD Athlon 64 Fx 60 + 1 GB DDR RAM.
My Budget is 15K. Currently not thinkin of buying Graphic Card.
I gotta lots of confusion between these ASUS mobo's. Pls, If anyone can tell me Prices of all hardware will make my burden less.
Also let me know regarding Processor and RAM (DDR or DDR-2)
If there r problems with this combination. pls suggest good Intels Combo.
boomstation2 is offline
Old 15-09-2006, 03:53 PM   #2 (permalink)
Default Re: Suggest ASUS mobo + AMD 64 fx best combination
The FX-60 alone will cost more than 30k. Intel Core 2 Duo is out of the question in your budget.
I suggest you get:
Asus A8N-VM Rs. 3800
Athlon64 3500+ Rs. 5200
Transcend 1 GB DDR400 RAM Rs. 4500
Total Rs. 13,500
If you can increase your budget just a little get the Athlon64 X2 3800+ for Rs. 8500. It's far beter than the 3500+. Total cost with the X2 3800+ is Rs. 16,800.
drvarunmehta is offline
Old 15-09-2006, 09:03 PM   #3 (permalink)
Intel Core 2 Duo > FX 62
akshayt is offline
Old 15-09-2006, 09:15 PM   #4 (permalink)
See his budget first. How can he get Core 2 Duo or FX-62 within 15k inclusive of mobo and RAM?
Old 15-09-2006, 09:37 PM   #5 (permalink)
I never said he can get a core 2 duo. He wanted a FX 60, I am just telling him that a 10k CPU of Intel > AMD's any CPU
akshayt is offline
Old 15-09-2006, 09:39 PM   #6 (permalink)
dOm1naTOr's Avatar
Ya accordin to his budget the best combination would be:
AMD 3500+ : 5300/-
A8NE : 5300/-
1gb ;4500/-
forget FX 60 + mobo + 1GB within 15K.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 15-09-2006, 09:41 PM   #7 (permalink)
A8N-E is not an option. He needs a mobo with onboard graphics.
Old 15-09-2006, 10:11 PM   #8 (permalink)
dOm1naTOr's Avatar
but as far its under 15 k he can consider a card too. nd why go for A8nVM nd trade on perfomance for that crappy onboard graphics.
@boomstation2
Also give ur needs also.
If u on gamin then gor for that 3500+, A8NVM nd a 7300GS[3.5k] or GT[5.2k] along with 512mb mem. all these would cost u 5200+3800+3500+2300/-=14800/-.
A8NE would cost 5200~5400/- dependin according to ur location
nd if u r not on gamin then 3500+, A8NVM, 1Gb mem[5200+3800+4500=13500/-]. U can make that mem 512 mb.[sorry for the wrong price]
or if want dual core then,
AMD X2 3800+ 8200
A8NVM 3800
512DDR 2300
14300/-
G3: XPS M1530 |
FZ 16.
Old 15-09-2006, 10:31 PM   #9 (permalink)
The config you have given for gaming far exceeds his budget. He has already said he dosen't want a graphics card so why add it unnecessarily?
You have quoted the wrong price for RAM. 512 MB is about Rs. 2300 and 1 GB is about Rs. 4500.
Last edited by drvarunmehta; 15-09-2006 at 10:31 PM. Reason: Automerged Doublepost
Old 15-09-2006, 11:25 PM   #10 (permalink)
coolsunny's Avatar
Transcend 512MB DDR is 2950/- now.
AMD X2 260, GA M68MT-S2P, Gskill RipjawsX 4GB, 500Gb Seagate, Cooler Master eXtreme Power Plus 600W, Altec Lancing atp3, Samsung B2230 TFT, Numeric Digital 600 EX-C UPS.
coolsunny is offline
Old 16-09-2006, 12:49 AM   #11 (permalink)
dOm1naTOr's Avatar
@coolsunny
Ive bought 2x512 transcent jetram for 2600 each bout 2 weeks ago. Dun know if the price has increased that much.
G3: XPS M1530 |
FZ 16.
Old 16-09-2006, 03:54 PM   #12 (permalink)
deathvirus_me's Avatar
WTF !!! did he actually look for the prices first ??
Anyway .. forget the FX60
AMD 3500+ : 5300/-
A8NE : 5300/-
1gb ;4500/-
Go for this one .. best budget AMD buy currently ..
Also .. the ram prices may be slightly higher ...
deathvirus_me is offline
Old 16-09-2006, 11:29 PM   #13 (permalink)
Smile Re: Suggest ASUS mobo + AMD 64 fx best combination
I suggest you get:
Total Rs. 13,500
Thanks drvarunmehta..
I probably made a mistake that i write AMD Athlon 64Fx 60. Actually i don't know what is "FX 60". Actually i thought of AMD 64 3500+ Processor (..around 5K). Is AMD socket 939 good for future or shud i go for AM2.
Juny..Suggest me a good combo of ASUS and AMD Processor.
I did sort out few..after reading forums -
1. A8N-E
2. A8N-VM CSM/NBP
3. A8N-VM
if i go for 1st one its better, but i can't buy a graphic card in my budget.If necessary for better future i am ready to buy a graphic card but i really can't iincrease my budget by more than 1.5 - 2 K.
I am confused in these mobo selection.
Even pls let me know reagarding the RAM. shud it be DDR (400 or 533). (Kingston or Hynix.or Transcend.?)
Many of my friends asked me to enquire about the performance of this combination. some says its gotta heating problem, it slows down after lot of use.. all these things make me crazy.
Old 16-09-2006, 11:52 PM   #14 (permalink)
dOm1naTOr's Avatar
AMD 939 mobo[preferably A8NE] with a gud ddr400 would beat even DDR2 667 normal in all benchmarks.
the best is to get
3500+: 5.2k
A8NE:5.3k
2x512 transcent or corsair or any gud one[not hynix,dynet] :5k
7300GS:3.5k.
u can reduce the ram to 2x256 as its exceeding 15k. u can later add another 2x512 in dual channel, so 256 nd 512 in both channel nd effective 1.5gb in dual channel.
so its 5.2+5.3+2.5+3.5=16.5k its the most better choice as the graphics would be almost 4 times or higher than the 6100 of A8NVM.
G3: XPS M1530 |
FZ 16.
Old 17-09-2006, 12:31 AM   #15 (permalink)
Get AM2 or Core 2 Duo preferably. 939 is obsolete now.
akshayt is offline
Old 17-09-2006, 01:26 AM   #16 (permalink)
Core 2 Duo is out of budget. Are good AM2 mobo's readily available? If they cost about as much as the 939 mobo's then AM2 is a good buy.
If not get the A8N-VM. Use onboard graphics for the time being and add a graphics card whenever you can afford it.
Old 17-09-2006, 04:12 PM   #17 (permalink)
Hi,
Thanks for all ur comments. i am pleased. I have started to sort out few combinations though few Q's r in my mind.
Give me the prices of following combo..and suggest me a better option.
Hope all these are available in MUMBAI
1. AMD Athlon 64 3800+ X2 (Socket AM2) + ASUS M2N-VM DH + 1 GB DDR
2. AMD Athlon 64 3800+ X2 (Socket AM2) + ASUS M2NPV-VM + 1 GB DDR
3. AMD Athlon 64 3500+ (Socket 939) + ASUS A8N-E + 1 GB DDR + graphic card (..?)
4. AMD Athlon 64 3500+ (Socket 939) + ASUS A8N-VM CSM + 1 GB DDR
Should i go for X2 processor or AM2 or 939. pls suggest few. I am not that much into Games..rarely play any. I want to be future ready.
Questions like...DDR2 or DDR ... AM2 or X2 or 939 creeps in my mind.
when i went thru AMD2 socket boards ..they can have DDR2 RAM.. is this what future will demand..?
The main thing is Mobo..which shud be very good.
Old 17-09-2006, 05:28 PM   #18 (permalink)
dOm1naTOr's Avatar
If u rn't on gamin then get an x2 AM2 nd 1GB DDR2. Later u can add a good DX10 card when they r out.
G3: XPS M1530 |
FZ 16.
Old 17-09-2006, 05:39 PM   #19 (permalink)
Get a Athlon64 X2 3800+ AM2 processor, ASUS M2N-VM DH and 1 GB DDR2 RAM.
If this is crossing your budget, there is a X2 3600+ dual core processor too. I don't know if it's available in India but if you could get it it would be the best option.
Old 17-09-2006, 07:31 PM   #20 (permalink)
X2 3600 is for 7k
akshayt is offline
Old 17-09-2006, 08:32 PM   #21 (permalink)
Then that makes it the best option. It's dual core and only slightly slower than X2 3800+.
Old 18-09-2006, 09:30 AM   #22 (permalink)
Originally Posted by akshayt
X2 3600 is for 7k
Can u tell me the prices of....following in Mumbai.
ASUS M2N-VM DH
1 GB DDR-2 800
(transcend, kingston..?)
Old 18-09-2006, 02:13 PM   #23 (permalink)
M2N from Asus is known for only troubles and they are good for nothing. Don't even touch them. Although I have read about M2N E and SLI, I wouldn't risk it without enough research.
akshayt is offline
Old 18-09-2006, 04:19 PM   #24 (permalink)
Post Re: Suggest ASUS mobo + AMD 64 fx best combination
Ohh now..its really making my head bump on table... Thanks Akshay for the recommendation. I really planed to buy the M2N-VM DH board. I thought it will serve me better.
Now pls can u suggest something better for me...Give me out few combinations. pls elaborate regarding DDR or shud go..for DDR-2
All my other friends pls ..give me ur comments on this. I really buy 1 system yaar..!!
Old 18-09-2006, 04:34 PM   #25 (permalink)
If the Asus mobo for AM2 is crap get an AM2 mobo from MSI or Gigabyte.
I suggest the MSI K9NGM2 or the MSI K9NGM. I don't know the cost but they won't be too expensive. Both have onboard graphics based on Geforce 6150 and 6100 chipset respectively. Get either of these motherboards, X2 3600+ and 1 GB DDR667 RAM.
Old 18-09-2006, 04:42 PM   #26 (permalink)
DDR2 for C2D and AM2. DDR for 939.
Try to get C2D.
What is the max budget and exact usage?
akshayt is offline
Old 21-09-2006, 04:51 PM   #27 (permalink)
After lot of confusions regarding processor(939 or AM2 ). I have decided to go for AMD Athlon 64 3800+ X2 (Socket AM2)...tell me thr prices for this in Mumbai...pls.
Now I wanna go for the good Mobo.....
Confusions between Asus & MSI.. b'coz few suggested that ASUS M2N series gotta Problems. I thought of going for MSI Boards..
Let me know how is the performance of the boards..of MSI
1. MSI K9NGM2 ........... Pls give me prices..
2. MSI K9NGM............pls give me prices..
3. ASUS M2NPV-VM .......prices pls
4. ASUS M2NPV-VM .....prices pls
Old 21-09-2006, 05:04 PM   #28 (permalink)
google.com
xbitlabs.com
akshayt is offline
