Old 15-09-2006, 08:44 AM   #1 (permalink)
Question SLI mode
Just wanted to know,would it be possible to setup SLI with a 7600GT XXX version and a non xxx 7600GT???
Intel C2D 6600lMSI P965 NeoFl2X1GB Transcend @ 667Mhz l250GB Segate HDDlLeadtek 7900GS l Creative Xfi Xtreme MusiclAltec Lansing MX5021lSamsung 940BWl Brand new XFX 7600XXX SOLD!
amigoatul is offline
Old 15-09-2006, 02:19 PM   #2 (permalink)
Default Re: SLI mode
hopefully should be fine but not recommended. rather get a single 1900xt or 7900gtx which will pwn those 2
__________
I am not sure whether it will work or bot but it is surely not worth taking.
Get the following instead:
1800XT 512
1900XT
akshayt is offline
Old 15-09-2006, 04:38 PM   #3 (permalink)
Stalker's Avatar
I think it shud work.........., but try getting a HIGH-END gfx card instead of two 7600's
| C2Q Q6600 G0 | Intel DG33FB | 4 GB Corsair 6400C5G DDR2-800Mhz | XFX 8800GTX | CM Extremepower 600W | 250GB Seagate HDD | Lite-ON 1635S DVD RW | Logitech MX-518 | Zalman RS6F | APC RS 800 |
Stalker is offline
Old 15-09-2006, 10:03 PM   #4 (permalink)
dOm1naTOr's Avatar
As hes mentioning a XXX verient nd a non xxx vairent, it seems he already have those..
Try postin it at XFX help cantre. They usually reply within 5 min. But u need to register first. Its free nd dun need any authorization nd nythin.
http://www.xfxforce.com/web/home.jspa?set_locale=en_US
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
