Old 14-09-2006, 04:55 PM   #1 (permalink)
Extheist
aditya1987's Avatar
Unhappy HDD showing less space!!
Hello friends.
I have recently bought 160 GB seagate sata HDD. But after formatting it is showing only 149 GB, not 160 GB. Where has another 11 GB gone
Please help me!!!!!!!
aditya1987 is offline
Old 14-09-2006, 05:07 PM   #2 (permalink)
aka. ViKiD? <^_^>
Ambar's Avatar
Cool Re: HDD showing less space!!
dude the HDD actually has capacity of 149 GB u can easily see wid other drives also...like samsung 80 GB has around 75 BG free space...so no prob wid the drive..
Ambar is offline
Old 14-09-2006, 08:00 PM   #3 (permalink)
Default Re: HDD showing less space!!
oh gos , 11 GB is too much , get ur HDD checkeed with ur dealer frm where u purchased ur HDD
signature??? :???: Let Me Think About It!!!:-D
paul_007 is offline
Old 14-09-2006, 08:24 PM   #4 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
No problem with his HDD dude.....
Hard disk companys don't see things in quite the way u do.1KB is considered equal to 1000 bytes.The actual number is 1024(which is raised to the power of 10).Now consider your 160 GB hdd is equivalent to 160,000,000,000 bytes according to the hard drive.The OS calculates the capacity using 1024 (correct binary calculation).Therefore, if u thke 160,000,000,000 bytes and divide that by 1024, the answeris 156250000KB.Divide by 1024 again to get 152587.890625MB.Divide this by 1024 and u get 149.0116GB..Its just that the hard drive companys round off 1024 to 1000 (which is not an accurate way of displaying the capacity of the drive)
SO stay calm and no need to panic........
wizrulz is offline
Old 14-09-2006, 09:09 PM   #5 (permalink)
160GB real = 160 X 1024 MB
160GB of company = 160 X 1000 MB = 160 X 1000 / 1024 GB = approx 156 GB
anyway even mine is around 148 GB
akshayt is offline
Old 14-09-2006, 09:26 PM   #6 (permalink)
Wandering in time...
Ankur Gupta's Avatar
My 250GB SATA 233 GB of Formatted space.
Its perfectly fine as manufactures make calculations as mentioned above by wizrulz.
Integrate Yourself With The Latest Happenings.....
www.ankur-gupta.com/blog
Ankur Gupta is offline
Old 14-09-2006, 09:30 PM   #7 (permalink)
Great explanation Dude.
Keep it up.
Regards
Amit.
amitsaudy is offline
Old 14-09-2006, 10:01 PM   #8 (permalink)
Thats the same reason u dont get 256 mb of ram u get only 224mb
nice explaination dude how do u get all these
cooldude is offline
Old 14-09-2006, 10:08 PM   #9 (permalink)
SE><IE
Posts: n/a
The "scraping off" starts at the very low levels i.e. from Bytes to KiloBytes.
so, 160GB is therotically 1024x1024x1024x160 Bytes
whereas it is 1000x1000x1000x160 Bytes
so the actual space that you get is ( Cx1000x1000x1000 )/ (1024x1024x1024)
where C is the theoritical capacity (160 GB in your case)
so in your case it comes out to be 149.0116119384765625 GB
in case of 80 GB it comes out to be 74.50580596923828125
@cooldude: No, the loss in case of RAM is due to sharing for graphics. If it were the other way, it would have been 244.140625
Hope this helped
EDIT: sorry I didn't read wizrules explanation
Old 14-09-2006, 10:58 PM   #10 (permalink)
Extheist
aditya1987's Avatar
Thanks wizrulz!!
Reputation added!
Old 16-09-2006, 08:39 PM   #11 (permalink)
aka. ViKiD? <^_^>
Ambar's Avatar
Thumbs up Re: HDD showing less space!!
ya @wizrulz..is rite..kewl man..
Ambar is offline
