Old 12-09-2006, 07:28 PM   #1 (permalink)
Default help me in getting the cpu
hi
i want to buy a pc
i stuck between the amd and intel ...
my friend says that opteron will perform better than 939x2 processors
also better than core2duo...
please help me in choosing the right one
ramana321388 is offline
Old 12-09-2006, 07:35 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: help me in getting the cpu
Opteron are basically server processors arent they? I'd suggest a Core2Duo 6300 or 6600 [budget higher!]
Tell us your budget...
Harsh J
www.harshj.com
QwertyManiac is offline
Old 12-09-2006, 07:38 PM   #3 (permalink)
yeah
my budget is 35000 exactly.....
Old 12-09-2006, 07:44 PM   #4 (permalink)
For the CPU or for the entire system.
Mention usage and components you want to buy
akshayt is offline
Old 12-09-2006, 08:21 PM   #5 (permalink)
dOm1naTOr's Avatar
If its for the cpu alone, u can get a hell of a proc. Probably an E6800.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
