Old 11-09-2006, 12:43 AM   #1 (permalink)
Default Processor and Mobo Pack....
hey bros,
i need 2 buy a good processor under 10ks, and a mobo for it under 7.
total budget 17k,s
just wanted 2 know, which 1 should i opt 4, AMD or INTEL and which 1
would be best value for money with performance. AMD x2 under 10k
or INTEL C2D under 10k.
as for the mobos, no need for the SLI mobos,,, just PCI-E and DDR 2.
4 AMD, AM2 necessary, and intel, 775.
help needed as fast as it can b,
need 2 buy it in this weak.
thanx
angel
The Day Walker! is offline
Old 11-09-2006, 01:59 AM   #2 (permalink)
UNREAL's Avatar
Wink Re: Processor and Mobo Pack....
I wud say go for Intel Core 2 Duo E6300 ! with a compatibel mobo with the desired features . i wud say go for E 6400 which will cost u 11.6k and rest 5.4k u will get a decent mobo....
@ all plz do correct me if i m wrong..
Er...Er........what the hell was i supposed to say ??
UNREAL is offline
Old 11-09-2006, 09:21 AM   #3 (permalink)
montylee's Avatar
Default Re: Processor and Mobo Pack....
For, processor: go for Core 2 Duo 6300.
For motherboard: Do u require on-board graphics?
Intel Core 2 Duo E6300, Intel DG965RY, MSI 8600GT OC, WD 250GB SATA-II Harddisk, Transcend 1GB 667 Mhz DDR2 RAM, Samsung Samtron 55V, Sennheiser HD485 cans, Zebronics LAVA Cabinet, Zebronics 400W PSU
montylee is offline
Old 11-09-2006, 09:49 AM   #4 (permalink)
for grafx card i m thinking of goin in for, xfx 6700
so suggest a mobo for it,,,,
i have checked out asus site, and the max i can think of is, p5b deluxe,
can i know the price for it, and any other mobo compared 2 it, in
gigabyte and msi,
wot would b the price of e6300 in mumbai, and difference in e6300 and e6400
thanx
angel
