Old 10-09-2006, 11:21 AM   #1 (permalink)
Question Device which directly let us draw on PC
Is there any device which directly let u draw on the PC ?
Where would it be available in mumbai at what price ?
Would the quality of image be nice?
Which brand?
cooldude is offline
Old 10-09-2006, 11:34 AM   #2 (permalink)
 Macboy
goobimama's Avatar
Default Re: Device which directly let us draw on PC
You meant draw directly "on" the screen or something that let's you move a stylus on a pad which is then reproduced on the screen? Cause the Wacom Grapphire 3 tablet costs around 4.5k for the lowest model (4x6). The best. Its got pen pressure sensitivity and all that whatnot.
Not sure about the "on" the screen drawing tools though..
I'm like a bird... :)
goobimama is offline
Old 10-09-2006, 12:04 PM   #3 (permalink)
No pain....No gain
john_the_ultimate's Avatar
Maybe he wants a touch screen thingy. Or else get a graphic tablet as goobimama has said but good ones r costly and cheap ones don't give the desired result.
john_the_ultimate is offline
Old 10-09-2006, 12:20 PM   #4 (permalink)
Stalker's Avatar
u can draw using a graphic tablet, costs around 5k
| C2Q Q6600 G0 | Intel DG33FB | 4 GB Corsair 6400C5G DDR2-800Mhz | XFX 8800GTX | CM Extremepower 600W | 250GB Seagate HDD | Lite-ON 1635S DVD RW | Logitech MX-518 | Zalman RS6F | APC RS 800 |
Stalker is offline
Old 14-09-2006, 06:55 PM   #5 (permalink)
Tux Fan
shaunak's Avatar
The class of devices you refer to are called natural input devices.
egs:
>UV or light pen
>Graphic tablets.
get the ones from Iball. they r cheap and durable.
i write is the light pen and idraw is the tablet available for about 3-4K
their site is enteriworld.com but it down temporarily.
you could also consider higher end options from logitech
Cheers
Shaunak
Feel free to PM/email me.
shaunak is offline
Old 14-09-2006, 10:09 PM   #6 (permalink)
Thanks 4 the help
cooldude is offline
