Old 09-09-2006, 11:47 PM   #1 (permalink)
Question Networking Issue
Networking Issue
Didnt know where to post so sorry if its a wrong place
I & my friend wants to share my broadband connection.
we calculated the CAT5 cable requied about 200 ms n cost upto 2000 Rs
its heavy for us plus a hub is required(additional).
I have heared about RJ11 to RJ45 & RJ45 to RJ11 converters, is it possible to use these converters n use a normal telephone line to setup network.
distance between our houses is about 100 meters.
what i am thinking is
is this possible
if not is there any other economical solution to our problem
ashman is offline
Old 13-09-2006, 07:02 PM   #2 (permalink)
Default Re: Networking Issue
try buying a router, this is the best solution for sharing a single BB connection. They are far superior that the modems. Along with it you get a lot of configuration options. I think there is a D-link 3000 or something like that. Once you have a router, you will not need a firewall in your system as well. Ask you service provider if you can use the router on their network.
slagad is offline
