Old 09-09-2006, 04:37 PM   #1 (permalink)
Mobile Addict
Smile Guide on buying PC peripherals
Can anyone help me!!!.
Can anyone tell me the price of a 1GB DDR2 RAM Module.
What is the minimum price of a Pentium Core 2 Duo processor for desktop and its frequency and a supported motherboard which supports a PCIe slot.
What will be the minimum price of an AM2 processor(specify frequency) and a supported motherboard.
Will buying any Pentium D processor be better than buying an AM2 processor or an AMD Athlon64 processor.
aritrap is offline
Old 12-09-2006, 08:34 PM   #2 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
Default Re: Guide on buying PC peripherals
WRONG SECTION DUDE..H/w SECTION
wizrulz is offline
Old 14-09-2006, 12:31 AM   #3 (permalink)
18 Till I Die............
Moved here
http://www.bash.org/?258908
mehulved is offline
Old 14-09-2006, 07:54 AM   #4 (permalink)
nishant_nms's Avatar
no pentim D is crap
nishant_nms is offline
Old 14-09-2006, 08:27 AM   #5 (permalink)
go_gamez's Avatar
Originally Posted by nishant_nms
no pentim D is crap
pentium D may be crap ..but dude...C2D(core 2 duo just rocks!!)
Intel P4 2.47 ghz with 1 MB L2 cache-HIS 845GVM mobo
512 MB DDR RAM .
Gainward 6600 gt golden sample edition(ultra 1960xp)
80 GB Seagate Barracuda 7200 rpm HDD
Sony QW -120A Dual Layer DVD writer.
go_gamez is offline
Old 14-09-2006, 09:53 AM   #6 (permalink)
gooby pls
Third Eye's Avatar
The price of 1GB DDR 2 @ 533MHz is Rs 4200 and brand is Kingston.
Third Eye is online now
Old 14-09-2006, 01:56 PM   #7 (permalink)
get corsair value select using d9 chips instead
akshayt is offline
Old 15-09-2006, 07:06 PM   #8 (permalink)
crazywolf
Posts: n/a
Lightbulb Re: Guide on buying PC peripherals
core 2 duo e 6300 cost 11k [which is the base processor]
Old 17-09-2006, 04:13 PM   #9 (permalink)
aquamatrix's Avatar
nah c2d e300 will cost you 9.5 to 10k
Intel Core 2 Duo E6300 | Gigabyte 945 GM S2 |2X1 GB DDR2 transcend @ 667 mhz| Samsung 740N (17in)| 200GB Seagate SATA HDD | LG H10N | logitech MX 518 | Steelpad 5L | Philips HP 805
aquamatrix is offline
