Old 09-09-2006, 07:37 AM   #1 (permalink)
nishant_nms's Avatar
Default Cheapest card for Vista
I want to know which cheapest Graphics card model from both ATI and nvidia which will support Vista Aero. Also quote it's price. And suggest for both AGP and PCIe
nishant_nms is offline
Old 09-09-2006, 08:53 AM   #2 (permalink)
deathvirus_me's Avatar
Default Re: Cheapest card for Vista
the cheapest would be the FX5200 ... but i'd suggest u to invest for a 6200 ..
deathvirus_me is offline
Old 09-09-2006, 09:04 AM   #3 (permalink)
go_gamez's Avatar
U Can Buy...a 6200 For Less Than 3000 Bucks...and A 6600 Non-gt..for 3600..i Think..this ..two Will Do..
Intel P4 2.47 ghz with 1 MB L2 cache-HIS 845GVM mobo
512 MB DDR RAM .
Gainward 6600 gt golden sample edition(ultra 1960xp)
80 GB Seagate Barracuda 7200 rpm HDD
Sony QW -120A Dual Layer DVD writer.
go_gamez is offline
Old 09-09-2006, 09:46 PM   #4 (permalink)
samrulez's Avatar
Fx5200 is the last card to support Vista.....and its only in the AGP....6200 seems to be enough....its in both PCIe and AGP.....
6600LE or 6600 is better than 6200 ....but really if u r not into gaming then a 6200 (64bit) (try 128bit) should be more than enough......
Sam :D Rulez :lol:
samrulez is offline
Old 09-09-2006, 10:34 PM   #5 (permalink)
Stalker's Avatar
Fx5200 is the last card to support vista, but i would advice u 2 go 4 a 6200 or a 6600
| C2Q Q6600 G0 | Intel DG33FB | 4 GB Corsair 6400C5G DDR2-800Mhz | XFX 8800GTX | CM Extremepower 600W | 250GB Seagate HDD | Lite-ON 1635S DVD RW | Logitech MX-518 | Zalman RS6F | APC RS 800 |
Stalker is offline
Old 10-09-2006, 01:37 AM   #6 (permalink)
dOm1naTOr's Avatar
U will need at least a 7300 to enjoy vista's eye candies. But an FX thing would do if u just wanna use Vista.
Heard that vista makes use of dual cores greately. nd also upcoming games like UT07 nd Crysis.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 10-09-2006, 09:52 AM   #7 (permalink)
A 32 bit SM2.0 supporting card will be enough to run Aero .. i.e. will handle Vista with all the visuals ....
Old 10-09-2006, 12:12 PM   #8 (permalink)
Stalker's Avatar
^^will a FX5200 do fine??
Stalker is offline
Old 10-09-2006, 12:31 PM   #9 (permalink)
gooby pls
Third Eye's Avatar
FX5200 is old card not sure that it supports some capabilities of vista.
Third Eye is online now
Old 10-09-2006, 01:46 PM   #10 (permalink)
FX5200 will do eekam ok ... just for the OS i.e. if u want Aero , and want it cheap
Old 10-09-2006, 04:21 PM   #11 (permalink)
samrulez's Avatar
Will there be any diff. in aero with FX5200 or a 6200 and a 6600.........not 'bout the gaming....
Sam :D Rulez :lol:
samrulez is offline
Old 10-09-2006, 07:56 PM   #12 (permalink)
dOm1naTOr's Avatar
On gf7 series only its given as 'Vista Ready' nd only seen in that series. Whys it so? Even GF6 doesn't seems to have it. If u can run aero on even a 5200 then whats the need for a 7 series?[ nd the word Vista ready]?
G3: XPS M1530 |
FZ 16.
Old 10-09-2006, 08:09 PM   #13 (permalink)
aquamatrix's Avatar
get a 7300 GT
Intel Core 2 Duo E6300 | Gigabyte 945 GM S2 |2X1 GB DDR2 transcend @ 667 mhz| Samsung 740N (17in)| 200GB Seagate SATA HDD | LG H10N | logitech MX 518 | Steelpad 5L | Philips HP 805
aquamatrix is offline
Old 10-09-2006, 08:13 PM   #14 (permalink)
You might as well get the 6200 over the 5200 considering there's practically no price difference between the two.
drvarunmehta is offline
Old 10-09-2006, 08:32 PM   #15 (permalink)
Only the later 7 series i.e namely 7800GT and beyond are said to be truly Vista ready as they have HD hardware support .. which is missing for the other cards ..
But as long as u keep the HD part out ... any SM2.0 compliant card is said to be vista ready .. starting from a FX5200 ..
Now for Vista , as its actually utilising the card , the UI effects will actually be better on the 6200 than the FX5200 , as the former has better dx9.0c support ..
Old 10-09-2006, 09:07 PM   #16 (permalink)
dOm1naTOr's Avatar
As far as I know both 7300 nd a 7800 has same features nd nothin more in a 7800. Its only bout perfomance.
G3: XPS M1530 |
FZ 16.
Old 10-09-2006, 09:23 PM   #17 (permalink)
deepgeek2's Avatar
CAN anyone tell me which PCI(not PCIe) based Graphic cards supports VISTA(if any). Please tell the price of cheapest one. I just need it for aero.
Pllleeeeeeeeaaaazzzzzzzzzzzzzzzzzzzeeeeeeeeeee add to my Repu points if you think i was helpful.
deepgeek2 is offline
Old 10-09-2006, 09:33 PM   #18 (permalink)
Stalker's Avatar
^^the pci version of FX5200........
Stalker is offline
Old 10-09-2006, 10:05 PM   #19 (permalink)
dOm1naTOr's Avatar
Heard somewhere that ATI is releasing its top line x1300 256mb in a PCI version. It si the visiontek brand thats makin this card.
source:
http://www.ntcompatible.com/VisionTe...CI_s71921.html
but it will be almost impossible to find the product in India, so get some 5200.
__________
nvidia has released the cheapes 7 series card for them who just want all the visuals of Vista with the most affordable price nd its SLI ready too:
The all new GF 7100 GS
http://www.nvidia.co.in/page/pg_20060905500750.html
it hasn't got HDR support. nd the mem interface is 64 bit. Butnits a SM3 nd has DDR2.
But it will be of no use for gamin as it would perfomance if not better tha a 6200TC.
G3: XPS M1530 |
FZ 16.
Old 11-09-2006, 08:49 PM   #20 (permalink)
deepgeek2's Avatar
@arvind & stalker: Thanks
Old 12-09-2006, 12:08 AM   #21 (permalink)
does Intel 915 with 512/1024 MB RAM supports areo in vista
Old 12-09-2006, 06:53 AM   #22 (permalink)
dOm1naTOr's Avatar
Ya it an be installed on a PC with 915 disp, but its not 100% vista ready. Ya u can enjoy aero atleast.
G3: XPS M1530 |
FZ 16.
Old 12-09-2006, 09:15 AM   #23 (permalink)
deepgeek2's Avatar
No problem as far as AERO is concerned.
Old 12-09-2006, 10:54 PM   #24 (permalink)
Have u got Aero working on 915 if yes then How much RAM is required for it.
Btw plz quote the price of above mentioned GFX too
Old 13-09-2006, 08:08 AM   #25 (permalink)
dOm1naTOr's Avatar
a 7300GS PCIE would cost u 4500/-nd as a 7100 is much lower han that in features nd perfomance it could no way cost more than 3k.
X1300pro PCIE performs like a 7300GS nd would be similarly priced.
G3: XPS M1530 |
FZ 16.
