Old 09-09-2006, 01:13 AM   #1 (permalink)
Default System hangs when i try to access DVD drive
My system gets hanged when i put a cd/dvd in DVD drive (LG). Earlier there was problem with DVDs alone. Now I am unable view even the ordinary CDs. But my drive works without any problem when my cpu is kept horizontal.
Where the problem must be ? Please help me.
Thanks in advance.
madhu84 is offline
Old 09-09-2006, 03:43 AM   #2 (permalink)
HELP AND SUPPORT
rakeshishere's Avatar
Default Re: System hangs when i try to access DVD drive
Plz give some More discription on this problem
rakeshishere is offline
Old 09-09-2006, 04:15 AM   #3 (permalink)
As I put cd/dvd in the drive system hangs within 1 min. This happens only when the CPU is kept in upright possition. But I can read & write both CDs and DVDs when the CPU is kept in horizontal position. I found this accidently. Where should the problem be ?
madhu84 is offline
Old 09-09-2006, 04:17 AM   #4 (permalink)
HELP AND SUPPORT
May be some problem with the ide cable b/w the hard disk and cd rom...jst open ur cabin and see for some loose connections.
Old 09-09-2006, 11:10 AM   #5 (permalink)
dOm1naTOr's Avatar
Or maybe the drive's reading lens is not tight in position. Give more information.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 09-09-2006, 04:34 PM   #6 (permalink)
not sure exactly but it's seems to be IDE cable problem. Re-connect it or change it. thx
blackdialer is offline
Old 13-09-2006, 07:06 PM   #7 (permalink)
Horizontal is the way to use it then.
slagad is offline
