Old 08-09-2006, 11:49 PM   #1 (permalink)
sourav's Avatar
Exclamation Is the RAM is damaged....
I was checking my RAm with MemTest86+. it founf some errors. The errors are in image format :-
1.
2.
Plz click on it and open it
We must accept finite dissapointment. But we must never loose infinite hope.
sourav is offline
Old 09-09-2006, 07:39 AM   #2 (permalink)
nishant_nms's Avatar
Default Re: Is the RAM is damaged....
Time to change RAM
nishant_nms is offline
Old 09-09-2006, 08:00 AM   #3 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
yup looks like it
vijay_7287 is offline
Old 09-09-2006, 11:14 AM   #4 (permalink)
dOm1naTOr's Avatar
DO u see any constant restarts or blue screen of death???Or do u get many CRC errors even while simply moving files across Hard disc or installing any exe?
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 09-09-2006, 11:21 AM   #5 (permalink)
k_blues24's Avatar
It seems that It's shopping time
Talk less than u know, Show less than u have ;)
Yesterday is History. Tomorrow is Mystery.
Today is a Gift, that's why it is called as
The PRESENT.
k_blues24 is offline
Old 09-09-2006, 12:21 PM   #6 (permalink)
Welcome To The Jungle
sysfilez's Avatar
ram prices are very high now. it has increased drastically.
Me n My Canon EOS 350D with EF 50mm f1.8
sysfilez is offline
Old 09-09-2006, 01:45 PM   #7 (permalink)
gooby pls
Third Eye's Avatar
Do you have any problem with your RAM ? system restarting,hangs.etc ?
Third Eye is online now
Old 09-09-2006, 08:43 PM   #8 (permalink)
-The BlacKCoaT Operative-
Rollercoaster's Avatar
hopefully u have OCed ur RAM a wee bit over or the ram modules are in warrenty....
otherwise u need to replace to prevent future troubles...
Rollercoaster is offline
Old 09-09-2006, 09:29 PM   #9 (permalink)
samrulez's Avatar
Actually....u r memory is damaged but....not necessarily.....even if the contact pins r corroded....then u might get thses errors....try cleaning them......
Also I think u don't get new memory unless u get BSODs or hangs or restarts........
Sam :D Rulez :lol:
samrulez is offline
Old 09-09-2006, 10:22 PM   #10 (permalink)
GaurishSharma.com
gary4gar's Avatar
offtopic:well AFAIK ram memtest86 the soft used to test ram is though booting through cd or floppy.then how did u manage to take screenshots??
gary4gar is offline
Old 09-09-2006, 11:18 PM   #11 (permalink)
sourav's Avatar
"DO u see any constant restarts or blue screen of death???Or do u get many CRC errors even while simply moving files across Hard disc or installing any exe?"
I don't get any constant restarts or BSOD but I get many a times CRC errors
"offtopic:well AFAIK ram memtest86 the soft used to test ram is though booting through cd or floppy.then how did u manage to take screenshots??"
Using mobile phone's camera
sourav is offline
Old 10-09-2006, 01:31 AM   #12 (permalink)
dOm1naTOr's Avatar
normally if ram is damaged u will most probably get errors while installing softies containing '.cab' files nd all nd it would be a crc error. Its not the complaint of disc as u can easily copy those to HDD.
Try installing the office XP or 98. Both contains big '.cab' files nd see if u get any CRC errors.
G3: XPS M1530 |
FZ 16.
Old 10-09-2006, 01:51 AM   #13 (permalink)
sourav's Avatar
I installed Ofiice 2003 and MS Virtual PC and I didn't get any CRC errors
sourav is offline
Old 10-09-2006, 01:57 AM   #14 (permalink)
Justtake out the ram nd clean the contact area with a soft cloth dipped in alcohol. or do a rubbing with an eraser[only the copper coloured area]. nd see if its ok now?
fate is offline
Old 10-09-2006, 02:01 AM   #15 (permalink)
dOm1naTOr's Avatar
How many mem sticks do ya have? try installing any one at a time if ya have more thn 1.
G3: XPS M1530 |
FZ 16.
Old 10-09-2006, 02:02 AM   #16 (permalink)
sourav's Avatar
thanks fake let me try. hope it works.
Does anyone here know about how to make 20 pin connector of SMPS to 24 pin connector as my motherboard suppports it.
sourav is offline
